You should check the connection of the part temp sensor, maybe it's unplugged.
If the problem still be there, depends on the actual temperature, disable it or call Hexagon !
I did a restart on my whole system to see if that would help at all. It did "fix" it for the time being. If it occurs again, I will call Hexagon. I was just curious if anyone on here had seen if before. Thanks JEFMAN
When using temp comp on the parts how long does the sensor need to be on the part before it reads the temp? If I use zero delay I've noticed I get temp...
does any body know anything about usetemperaturecompensationV2 to false. in the settings editor..I have done this but i need to manually input temp settings...
