I have been using PC-DMIS 2015 and find that when using auto circles the feature color is inconsistent. Typical when selecting a pattern of holes the first one is blue and the following revert to black. Is there any way of stopping this. I set the color to blue (or any other color for that matter) in Setup Options/ID setup and the same thing happens.
Auto circle feature colors not the same
But on another note:
I have found that in 2019R2, that sometimes the features are 'ghosting' in different coordinates than the 'original' feature resides.
In 2015.1, if I use Widths, I see this "ghosting" fairly often. The Graphics Display Window shows 2 widths, one where it should be and one in a random spot out in space. The Edit Window shows the correct values in the ACTLs, but it will calculate dimensions using the "ghosted" location. I have to F9 the Width, select and deselect a third feature (so nothing actually is changed, but it will force it to recalculate). Then it will ask if I "want to update nominals for related dimensions" (this question popping up is how you can tell it recalculated- it did not recalculate if this question doesn't appear). I click Yes and now there is only one Width in the Graphic Display Window and associated dimensions are now calculating correctly. Because this happens so often, I try to avoid widths and only use them to get needed bonus.
by inspector212How do I change the color of the features in the CAD window. The points are at nominal. There is no deviation. Two are green and two are red. I have both...
06-08-2007, 12:30 PM -
by vlmitkovHello guys
I have the following question - is there a way to set the default colors for different types of features - i.e. by default every time...-
10-05-2018, 03:50 AM -
by AuRulesI'm nine (9) programs behind and going to this new version of PCDMIS also tried to look and find this simple problem but can't, how do you turn on ending...
02-26-2019, 10:50 AM -
by jkb_mcgI know I've discussed this before on here but I couldn't find it....
Does anyone have problems in 4.2mr1 with the dimension colors staying...-
08-18-2008, 02:24 PM -
Is there any way to change the dimension type colors? I know how to change the dimension tolerance colors, but the dimension type colors....I have no...
04-05-2012, 03:29 PM -
