I have not touched a CMM in years so please be gentle. Will I get an accurate/repeatable cone measurement if the cone is 0.120" deep has an angle of only 3 degrees?
Depends on many things. Condition of cone; is it round? etc. What size probe? How many hits? What type of machine? Which version of the software? How good is good enough? (+/-.5 deg, .25 deg, etc.)
Try to get at least 9 hits on each of 3 levels and you should be ok. HTH
What Wes said. Also, try writing a short program for just that feature. Then run it a number of times. Move the part between runs to see what kind of repeatability you get. Kind of a mini R&R.
I measured a ID cone (in). The first time was fine. The 2nd time, Pc-Dmis automatically changed the cone to OD (out). The measurement passed but the...
I have found that when measuring a cone with a measured feature the location of the measured cone is not accurate. I was using 4 points on 2 levels....
