So I have this round part and the program we have uses several scan segments to create a circle. The problem is that sometimes the scan appears on the wrong side and the results are completely wrong. I don't know how to fix this, sometimes I've turned off/on the machine and that works sometimes, but right now nothing seems to work. Does anybody know what's wrong?
Scan Segment Issues
Is this a part/program with a long history? Or it's relatively new? Sometimes (hate to use the word 'sometimes'.....can be frustrating!) it helps to re-create the scan for starters...and possibly increase the scan density.
The above is if you use an analog probe, but if your machine 'pecks' to scan you can adjust density.. i think its under the execution tab at the top -- min/max increments
by PDARRWell I changed a TTP scan to an analog scan and I get a window that tells me "cannot find nominals for some hits." I have changed the find nominal...
04-23-2014, 09:11 AM -
by Tomi530iGood morning all
I have a nooby question.
When I'm using auto feature I can change the measurement strategies to Adaptive Scan...-
02-08-2016, 06:19 AM -
I am scanning the od of a part. The first time it runs great. The next run it will start taking points around the part instead of a scan. I'm using a...
11-23-2009, 03:58 PM -
by zeljkoHello,
I tried to insert scan and when I executed program, machine doesn't do scan, but touching? Also, when I add auto plane feature with...-
05-10-2018, 02:51 PM -
by cfranklinI wondering how do you use the scan function using version 3.5????
11-10-2008, 01:18 PM -
