Star probe orientation that i build not squared to cmm axis
  • Star probe orientation that i build not squared to cmm axis
    Hi to all, I'm new to this forum. I have question star probe that not squared to cmm axis. how to fix this?
    Brown & Sharp - global
    pc-dmis 2019R2
    loosen the bottom stylus, adjust the start until it is square, and hold it there while tightening the bottom stylus
      I remove the #2 tip and use a 1-2-3 block (clamped on the table) and align it as close as possible. Keep in mind that it will 'turn' slightly as you tighten the #1 tip.
      • A-machine-insp
        A-machine-insp commented
        To this point, when I am tightening a star or angle probe, I anticipate it rotating when I tighten it so I keep it a bit off square before I tighten it then it squares up when it gets tight. They can be a pain but they get easier the more you build them.
      Thanks, now I need calibrate
        Thanks
          I still find it easier to eyeball it, take shank hits from T2 and T4 on a small diameter stand off while watching last hit in probe readout, and correct as needed. A star with 20mm long shanks is easy to get within .010" this way and yu know exactly how close it is before full calibration... 2 manual hits tells you the difference in y offset which indicates how square it is.
          If I was using a 123 block I would do this using an edge of it not using a flat face at all
