Work at home smarter with PC-DMIS
  • Work at home smarter with PC-DMIS
    After installing Pc-Dmis 2020 R1 using work from home free license, I'm getting " The License file cannont found " Msessage
    Same here.
    I emailed the address I was sent the instructions from, but have had no reply.
    Applications Engineer
    Hexagon UK
    • Douglas
      Douglas commented
      I never even got a reply for my original request to use the offline license and gave up... maybe they phoned the employer and got somebody who knew nothing about it but never heard a peep at all from Hexagon after trying to register
    At what point do you get this message? When starting the app? When opening a routine? When executing?
    Is this computer connected to the internet when this happens?
    It might be worth running the Settings Editor and checking the UseLMSLicensing to verify it is set to 1.
    • NinjaBadger
      NinjaBadger commented
      Install seems to go okay, then when you try start pc-dmis you get this error message.
      Can't access settings editor either.
    Don Ruggieri
    Looking in Regedit I get the following
    So UseLMS is set to 1 but license type is HASP?
    Hexagon UK
    • Kp61dude!
      Kp61dude! commented
      They send you a HASP/dongle for this 'free' license?
    • NinjaBadger
      Nope - that's just what it says in the registry.
    • Kp61dude!
      Kp61dude! commented
      O !
    License Server Dialog.JPGI found a solution for it not finding the license..
    Download the legacy version of 2020 R1 from February
    • Don Ruggieri
      Don Ruggieri commented
      WIth the LMS server license option enabled, and the "@pcdmis-codefromhome.hexagonmi.com" text entered into the License Server field, it should not matter which build of 2020 R1 you choose to use. The license expiration date is well beyond either of these build dates. When you start the install, until it "loads" this license, there will be a message at the bottom of the license dialog indicating that a license is not found. That is because at that point there is no local license found. I've attached an image of this dialog for reference. Just press the NEXT button to proceed, don't let this license error mis-lead you.
      ps: Sorry that the image is attached as preceding the original post, I will see if I can fix that later.
    • Tiago Ferro
      Tiago Ferro commented
      Hello, I've the same problem. Tried both versions anda the same result "could not communicate with license server".
      I've talked with our IT tech and he told me that our computers are not getting any ping response with hexagon servers.
      I'm trying to install in my laptop that didn't have any previous PC-DMIS instalation.
    • A_Shomshor
      A_Shomshor commented
      Same problem here Tiago Ferro
    Thanks I'll try that
    Hexagon UK
      When I try it says my license expired and won't finish the install. I've tried both versions of 2020 available to download and put the string "@pcdmis-codefromhome.hexagonmi.com" in the LMS License Server section per the email... I'm trying to install it on a computer that currently has an online seat running 2015.1. Do I have to install it on a computer without PC-DMIS on it???
      • Don Ruggieri
        It does sound like it is looking at a HASP license, and not the LMS Server license. Please confirm/reply that you do not have a HASP installed when this is happening.
        Its either that or there is a previous (local) LMS EID it is using, which in fact does have an expired date for this particular install of 2020, We could use CLM to remove that license, and use this temporary license, but that could get us into a situation which is more detrimental in the long run.
        So yes, I would recommend you use this CodeFromHome temporary license on a different computer where you did not already have a PC-DMIS license.
      • Mike Ruff
        Mike Ruff commented
        Thanks for the reply Don Ruggieri. The SMA for PC-DMIS on this computer expired in 2016, so I'll just try it on a different computer.
      Sorry, I was out today. Are you still having this issue? You do not need to install it on a separate computer, but it does sound like it is getting confused with the license. Run CLM and see how many LMS EID's it finds. Maybe it is grabbing the wrong one?
        i uninstalled 2020 R1 and installed 2018 R2, it works......................
        but sometimes i get same message "License not found ", at that time i use to re-start my Laptop......
        And also it lags speed, for every mouse click it takes time to complete the action............
          Don Ruggieri I'm still having this issue.
          Tried both versions of 2020.
          I have previous (HASP installed) versions on the PC - could that affect it?
          Also I'm not familiar with the LMS system. If I look in CLM what should I expect to see? Are we borrowing a licence (Options tab, borrow licence tick box?).
          Hexagon UK
          • Don Ruggieri
            I will try to address as many as I can of these issues, starting here. If you are trying to take advantage of the WorkFromHome initiative, please make sure the HASP is removed. If it is still problematic, please use the Settings Editor to export the registry keys and share it with me.
          Maybe an undocumented enhancement?
          I just take my hasp home with me at the end of the day (work is OK with this as I do fix programs from home after I leave for the day). If I know I'm going to be off for a while it goes with me
          Contura Calypso 5.4
            Not working here as well. I get the same error message. Unable to open settings editor as it says I need admin privileges even though I run it in admin. Tried 2020 and legacy versions.
              Just a shot in the dark..... If you have an older version of CLM (like 1.5) maybe try uninstalling it first?
              NinjaBadger -- I also have a HASP (offline) install...(several of them) and I was able to install 2020 R1 sp1 my second try.... good luck amigo!
              • Don Ruggieri
                Good point SeaLevel.
              nothing works for me. i gave up. thanks hexagon. i knew it was to good to be true
              • Don Ruggieri
                At least give me a chance to resolve your issue, what is happening?
              Don Ruggieri
              I've tried complete uninstall of 2020 and both 1.5 and 1.7 CLM. Then re-installed from scratch as admin.
              As before the install seems to go fine.
              It's when I try to start the software I get the error. (same as on the OP).
              If I look in CLM what should I see in there? Should it show a licence? is this a borrowed licence? or what?
              Hexagon UK
              • Don Ruggieri
                Good question, in CLM (1.7 on my system) it will not appear, as it is not an installed license. Let me check on this and other ways to confirm it is configured properly. I believe there are a couple of registry entries that are associated with this.
                Check these settings please, in the Settings Editor, Licensing section -
                LmsLicenseServers set to @pcdmis-codefromhome.hexagonmi.com
                UrlToFnoServices set to https://licensing.wilcoxassoc.com/flexnet/services
                UseLMSLicensing set to 1
                and this one in the registry editor
                LicenseType set to LMSLicenseServer
