https://www.wilcoxassoc.com/public/P...20_R1/SP1/x64/
ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve...20_R1/SP1/x64/
Release Notes - 2020 R1
SP1
• PCD-147628 - Fixed an issue where the path line for the adaptive cone
concentric circle scan was incorrect when the start angle and end angle were
changed.
• PCD-159921 - Fixed an issue where PC-DMIS displays an error when the
number of hits or the density value was set greater than 1000 in the Spline
Path area on the Path Definition tab in the Scan dialog box.
• PCD-160138 - Fixed an issue where PC-DMIS would hang when you used a
RomerRDS arm, and the distance to target with auto zoom is enabled on the
Probe Readouts Setup dialog box.
• PCD-161301 - Fixed an issue where the z-axis was missed when you
automatically inserted Location for a Laser circle.
• PCD-162438 - Corrected an issue where the Remove points with normals
outside check box was not available in the Laser Auto Feature dialog box
when the pointcloud was imported as an STL file type. For existing
measurement routines, the STL file needs to be re-imported so the normal IJK
values are calculated.
• PCD-171107 - Fixed an issue where you could not extract Extended Surface
Point features when you marked the Remove outliers check box in the Laser
Auto Feature dialog box.
• PCD-173273 - Fixed a crash that occurred when you typed the FCF
command and pressed F9 with no features selected.
• PCD-176095 - Fixed an issue where the Skip and Jump buttons were not
available in the Execution dialog box when you executed an optical
Extended Sheetmetal Feature.
• PCD-177031 - Fixed an issue where the Temperature Compensation dialog
box did not show text properly when you set PC-DMIS to the dark theme.
• PCD-179194 - Fixed an issue where PC-DMIS had displayed the Feature
failed to execute dialog box from the On Error command in automation.
• PCD-179545 - Fixed an issue where the values on the Pointcloud Colormap
gradient scale defaulted to three decimal places of accuracy when it was
expected to be more than three decimal places.
• PCD-179890 - Fixed an issue where PC-DMIS did not draw the minimum and
maximum annotations of Pointcloud Thickness Colormap correctly at the XYZ
location.
• PCD-180004 - Fixed a software crash that occurred when you tried to delete
and undo the Thickness Scan and Thickness Gage features.
• PCD-183193 - Added a support feature for Service Engineers to measure
scan noise at the installation location.
• PCD-183249 - Fixed a software crash that occurred when you pressed the
emergency button on arm 1 or arm 2 and the machine goes into an
emergency mode.
• PCD-184311 - Fixed an issue where the Quick Feature (Shift + Click) method
did not create a Laser Auto Feature because the dense Pointcloud covered
the CAD model.
• PCD-184346 - Fixed an issue where the trapezoid had appeared when you
programmed extracted Laser ESF features.
• PCD-184966 - Fixed an issue where PC-DMIS would clear the Remove
Outliers check box when you execute a measurement routine. This made it
impossible to apply the Remove Outliers process on all features except for
Plane features.
• PCD-185291 - Fixed the issue where you could not close the Exclusion
Plane dialog box from the Portable arm after you measure the Exclusion
plane.
• PCD-185347 - Fixed an issue where Edit window failed to print when you
select the Prompt option in the Output Configuration dialog box.
• PCD-185395 - Fixed an issue where all the deviation values were zero when
you marked the Force computation check box in the Extended Sheet Metal
Features dialog box.
• PCD-185560 - Fixed an issue where the Roughness Feature ID did not
appear in capital letters in the Edit window when you created it in the
Roughness Scan Evaluation dialog box.
• PCD-185686 - Fixed an issue where the Pointcloud display changed a little
when PC-DMIS was online with a laser probe and the cloud was not rotated in
the Graphic Display window.
• PCD-185751 - Fixed an issue where the extraction of a circle feature from a
perfect cloud created on a 20mm circle always returned a bigger diameter
value after you executed the measurement routine.
• PCD-185974 - Fixed an issue where the context mapping didn't work in the
Microsoft Edge browser for Offline Help when you pressed the F1 key on any
feature or dialog box.
• PCD-186426 - Added an update to the SimilarProbeComponents.xml file that
is located in the installation folder. This file provides a list of all the
components sold by Hexagon on the Web shop.
• PCD-186469 - Fixed a mathematical error that PC-DMIS uses to calculate the
center of the T2 tip of the Roughness sensor probe from the kinematics file.
• PCD-186515 - Fixed an issue where PC-DMIS now retracts the roughness
scanner needle before the Avoidance Move Position location instead of at the
Avoidance Move Position location.
• PCD-186606 - Changed the probe start position when measuring roughness
in small holes from the self-centering point to the center of the hole.
• PCD-186651 - Fixed an issue with an inconsistency between the segregated
points (orange) and the analysis points (green) for Laser Plane auto feature.
• PCD-186714 - Fixed an issue where scanning circle paths for Adaptive Scan
strategies was incorrect.
• PCD-186746 - Fixed a crash that occurred when you pressed F9 on the
LOADPROBE command.
• PCD-186763 - Added the ONERROR/LASER, SKIP functionality to a
measurement routine that contains failed ESF (VWMP) commands and is
managed as the standard Laser Auto Feature.
• PCD-186995 - Fixed an issue where the camera was not able to find the
focus position during the optical calibration when the Move to focus position
check box was not marked in the Setup Options dialog box.
• PCD-187016 - Fixed a software crash that occurred when you execute a
measurement routine from Inspect that contains a Form command.
• PCD-187266 - Fixed an issue where the QdasData.xml file was broken for the
Size dimension.
• PCD-187363 - Fixed a software crash that occurred when you executed a
measurement routine that contains a Pointcloud Point Colormap and selected
the Dots check box in the Pointcloud Operator dialog box.
• PCD-187390 - Added a probe component that was not available in the Probe
description list in the Probe Utilities dialog box.
• PCD-187441 - Fixed an issue where Q-DAS Configurator was not able to
read the second and subsequent Size dimension modifiers.
• PCD-187471 - Fixed a translation issue where the Probe Toolbox in the
Auto Feature dialog box did not appear correctly in the Italian language when
you select Adaptive Free Form Plane Scan in the Measurement Strategies
tab.
• PCD-187491 - Updated the syntax of the Dimension command format in the
Edit window for the Extended Sheet Metal Features.
• PCD-187553 - Fixed an issue where PC-DMIS did not update a 2D distance
or 2D angle dimension when you inserted the WORKPLANE command.
• PCD-187822 - Fixed an issue where the range of Size dimension was not
reported in Q-DAS output files.
• PCD-188072 - Fixed an issue where a few GD&T icons did not appear
correctly in the Excel Form Report.
• PCD-188086 - Fixed an issue where Q-DAS Configurator was not able to
read datum features from the Legacy True Position dimension.
• PCD-188339 - Fixed a feature calculation error issue that occurred where you
executed a Laser Auto Circle when the start and end angles were used.
• PCD-188408 - Fixed an issue where the .dfq file displayed a positive value
instead of a negative value of K-field K2112 (Lower Allowance) for Legacy
Profile form and Location Dimensions.
SP1
changed.
location.
emergency mode.
the CAD model.
Plane features.
plane.
LOADPROBE command.
Size dimension.
tab.
