error on scan
  • error on scan
    I got this error on my scan about cannot find nominals on hits. what would cause this?
    You in inch or MM ? I have made this mistake before ! Does it make it through the whole scan and then give you this error ? I would start with verify that the surface vectors are correct and that all the actual surfaces you are trying to scan were " selected " when you generated scan.
    • mbatten
      mbatten commented
      You beat me to it!
    The CMM finds the nearest surface in your CAD model to the measured hit in order to figure out what direction it should compensate the probe diameter. The "find nominals tolerance" defines when it gives up - if no CAD surface is closer than that, it will give you that message.
    Make sure that that number is at least half your probe diameter plus whatever variation you expect to see in the surface you're scanning. If you've increased to that point and even a bit beyond and it's still not working, make sure:
    1. Your alignment is good.
    2. The surface is where you think it is.
    3. You're not slipping off the surface at some point. This one gets me sometimes - I'll be trying to get close to an edge, and if the edge break is a bit bigger than I expect, I'll get all kinds of whacky numbers at that point. Also, is there a hole that it's running over?
    If you still have the box up, I would start by increasing that number by 50%-100% and checking "change for this run", and see 1) if it works (the box will come right back if it doesn't) and 2) if the resulting scan data looks right.
    • ginnbob
      error when I go to scan
      by ginnbob
      this is the error I get when I go to scan: enter no more than 10 characters. why did it start doing this? It won't let me finish programming a scan....
      02-18-2020, 02:43 PM
    • PDARR
      Scan Issues
      by PDARR
      Well I changed a TTP scan to an analog scan and I get a window that tells me "cannot find nominals for some hits." I have changed the find nominal...
      04-23-2014, 09:11 AM
    • kibbe
      scan-out of memory
      by kibbe
      I am trying to run a small scan on a die for a customer.
      I get an "out of memory" error when I try to start a scan, they said that is...
      08-13-2009, 03:32 PM
    • Tomi530i
      Scan with SP25M nooby question
      by Tomi530i
      Good morning all
      I have a nooby question.
      When I'm using auto feature I can change the measurement strategies to Adaptive Scan...
      02-08-2016, 06:19 AM
    • MIKEY
      Scan
      by MIKEY
      Hey guys long time no see. I need you'r help,
      I am doing a linear close scan. I need to tell the cnc programmer the proffile of the scan...
      04-04-2008, 12:07 PM
