flatness CZ
  • flatness CZ
    I have 2 planes on a drawing. There is a callout for flatness CZ between the two planes. Do I need to take hits on each and then use those hits to create 1 plane, then call out the flatness of the 1 plane?
    YES ! CONTINIOUS ZONE. Both " separate " features are " considered " 1 feature.
      Thank you
        You can make feature set from 2 planes or make bestfit plane with code pnl1.hit[1..pln1.numhits], pln2.hit[1..pln2.numhits]
        • Mike Ruff
          Mike Ruff commented
          The plane should be constructed from the hits of the 2 planes. Don't use a feature set
        I've found scans don't work either. Individual hits!
        • neil.challinor
          neil.challinor commented
          Scans work but you probably need to reference the hits if you're using more than one scan - i.e.
          PLN3       =FEAT/PLANE,CARTESIAN,TRIANGLE,NO,LEAST_SQR
                      THEO/<33.504,35.325,0>,<0,0,1>
                      ACTL/<33.58,35.317,0>,<0,0,1>
                      CONSTR/PLANE,BFRE,SCN1.HIT[1..SCN1.NUMHITS],SCN2.HIT[1..SCN2.NUMHITS],SCN3.HIT[1..SCN3.NUMHITS],
                      OUTLIER_REMOVAL/OFF,3
                      FILTER/OFF,WAVELENGTH=0
        Neil,
        Don't you need the ,XYZ?
        HTML Code:
        CONSTR/PLANE,BFRE,SCN1.HIT[1..SCN1.NUMHITS].XYZ,SCN2.HIT[1..SCN2.NUMHITS].XYZ,SCN3.HIT[1..SCN3.NUMHITS].XYZ,
