Hello,
I am looking to use the assign command to create a basic function and then report it with a comment report command. I will need to place tolerances on the assigned function, which will turn the variable red when the value is outside of the tolerance spec. I have figured out how to use the assign command to create the function and display it, but I do not know how to assign the tolerances, and change the color to red.
Any help would be greatly appreciated.
