2019 r1 sp8
  • 2019 r1 sp8
    During Covid-19, updating goes on...
    ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve...19_R1/SP8/x64/
    https://www.wilcoxassoc.com/public/P...19_R1/SP8/x64/
    Release Notes - 2019 R1 SP8
    • PCD-147628 - Fixed an issue where the path line for the adaptive cone
    concentric circle scan was incorrect when the start angle and end angle were
    changed.
    • PCD-159921 - Fixed an issue where PC-DMIS displays an error when the
    number of hits or the density value was set greater than 1000 in the Spline
    Path area on the Path Definition tab in the Scan dialog box.
    • PCD-160138 - Fixed an issue where PC-DMIS would hang when you used a
    RomerRDS arm and distance to target with auto zoom is enabled on the
    Probe Readouts Setup dialog box.
    • PCD-162438 - Corrected an issue where the Remove points with normals
    outside check box was not available in laser Auto Feature dialog box when
    the pointcloud was imported as an STL file type. For existing measurement
    routines, the STL file needs to be re-imported so the normal IJK values are
    calculated.
    • PCD-164330 - Corrected an issue where if you ran PC-DMIS online and
    opened the Auto Feature dialog box and manually changed the probe
    position, PC-DMIS didn't show and update the position.
    • PCD-165032 - Fixed an F9 issue where datums were added before the FCF
    command and not after the command.
    • PCD-167497 - Fixed the issue when you clicked a button on the Measured
    Feature toolbar, and your active probe is on a portable arm, PC-DMIS would
    not create the correct feature type.
    • PCD-169815 - Fixed a per-unit Straightness issue that allowed the diameter
    to report twice.
    • PCD-171551 - Fixed an issue where the Autofeature Edge Point (Focus Off)
    failed to create an edge when you switched on the laser beam with the Laser
    ON/OFF button in the Probe Toolbox dialog box.
    • PCD-172111 - Fixed an issue where the Close button overlapped the text of
    the Reorder title.
    • PCD-173016 - Fixed an issue where some spherical surfaces didn't tessellate
    correctly.
    • PCD-173273 - Fixed a crash that occurred when you typed the FCF
    command and pressed F9 with no features selected.
    • PCD-174711 - Fixed an issue where the save operation hangs when you save
    a large STL file.
    • PCD-176095 - Fixed an issue where the Skip and Jump buttons were not
    available in the Execution dialog box when you executed an optical
    Extended Sheetmetal Feature.
    • PCD-177118 - Fixed an issue where the user interface was not responding
    after simulation of a Laser scan, such as a Laser linear open scan.
    • PCD-177331 - Fixed an issue where the extraction from a pointcloud was
    incorrect when a few points existed on the radius of a laser auto slot.
    • PCD-177382 - Fixed an issue that caused the nominal values to change to
    incorrect measurement units when a Size tolerance was entered in an
    XactMeasure command.
    • PCD-180688 - Fixed an issue where values weren't parsed correctly when
    XYZ files were imported as CAD.
    • PCD-181556 - Fixed a software crash that occurred when you cancelled a
    vision probe tip offset calibration where a focus operation was active.
    • PCD-182117 - Fixed a delay that occurred when you created Cross Sections
    with a Mesh data object.
    • PCD-183181 - Fixed a software crash that occurred when you closed PCDMIS.
    • PCD-183520 - Fixed a software crash that occurred when you clicked on the
    top surface of a cylinder that looks like an ellipse during the Roughness Scan
    or other toolkit features with the self center method.
    • PCD-185104 - Fixed a software crash that occurred when the Test button in
    the Laser Auto Feature dialog box was used to extract an auto circle from a
    pointcloud.
    • PCD-185388 - Fixed an issue where PC-DMIS would hang with large CAD
    models.
    • PCD-185686 - Fixed an issue where the Pointcloud display changed a little
    when PC-DMIS was online with a laser probe and the cloud was not rotated in
    the Graphic Display window.
    • PCD-186651 - Fixed an issue with an inconsistency between the segregated
    points (orange) and the analysis points (green) for Laser Plane auto feature.
    • PCD-186691 - Fixed a software crash that occurred when you press the Esc
    key after you selected the Select Pointcloud option from the QuickCloud
    toolbar.
    • PCD-186714 - Fixed an issue where scanning circle paths for Adaptive Scan
    strategies was incorrect.
    • PCD-186763 - Added the ONERROR/LASER, SKIP functionality to a
    measurement routine that contains failed ESF (VWMP) commands and is
    managed as the standard Laser Auto Feature.
    • PCD-186995 - Fixed an issue where the camera was not able to find the
    focus position during the optical calibration when the Move to focus position
    check box was not marked in the Setup Options dialog box.
    • PCD-187016 - Fixed a software crash that occurred when you execute a
    measurement routine from Inspect that contains a Form command.
    • PCD-187179 - Fixed an issue that caused the nominal values to change to
    • PCD-187266 - Fixed an issue where the QdasData.xml file was broken for the
    Size dimension.
    • PCD-187441 - Fixed an issue where Q-DAS Configurator was not able to
    read the second and subsequent Size dimension modifiers.
    • PCD-187822 - Fixed an issue where the range of Size dimension was not
    reported in Q-DAS output files
