How to measure the Perpendicularity DIM from two lines to A Datum
How to measure the Perpendicularity DIM for this case, I measured these two lines and contruct Perpendicularity Dimension from these two lines but PC dmis gave me zero value..Please help me this !
Thanks a lot !
Did you try to construct perpendicularity between these 2 lines? Are these 2 lines not parallel to each other? You should construct perpendicularity to datum A with each of these 2 lines.
How to measure the Perpendicularity DIM for this case, I measured these two lines and contruct Perpendicularity Dimension from these two lines but PC...
OK, here what I am doing I am measuring an AutoSlot and I get center X.001 Y.002 but if I measure 2 opposite lines and then create a midpoint I get a...
I attached a screen shot for reference. Not easy to explain so hopefully that helps. I need to create intersection points between LIN1/LIN2 and a virtual...
