I have basically 2 notches one on each end of the part. They are different widths but share the same centerline and the centerline is datum. I was going to make 4 planes,2 on the left and 2 on the right. Then construct a mid plane on the right and left. My question is then what? Construct a plane with the 2 mid planes then level? Can that even be done with only 2 planes since it is from the centroid of the planes? Or would I be better off constructing mid points from each notch end. Then construct one mid plane from all of the mid points? Or do both options do the same thing and I’m just overthinking this?
Leveling mid plane
by BIGWIG7I have a datum that is 2 separate plane surfaces with opposing vectors but on the same center line.
What is the best approach: creating...-
02-28-2023, 11:52 AM -
by #2#I am measuring a plane on two oposing sides of a part. I want to create a plane centered between these two planes so I can measure how far from center...
07-27-2006, 10:04 AM -
by grantoAm i wrong but i figured it would be a simple venture to take two planes that are on opposite sides of the part, called out as datum C, and construct...
01-27-2020, 06:11 PM -
by ptedrumI'm trying to construct a plane perpendicular to another plane, I'm hoping someone can tell if there is and easy way to construct the plane with the contructed...
07-31-2007, 10:41 AM -
by XlarXlarHi,
I'm trying to construct a plane out of three Auto Plane measurements. I've had to use 3 separate auto planes to avoid a hole in the...-
02-03-2015, 10:45 AM -
