Have a nice reading
http://software.hexagonmi.com/public...19_R2/SP4/x64/
ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve...19_R2/SP4/x64/
Release Notes - 2019 R2 SP4
•PCD-147628 - Fixed an issue where the path line for the adaptive cone concentric circle scan was incorrect when the start angle and end angle were changed.
•PCD-159921 - Fixed an issue where PC-DMIS displays an error when the number of hits or the density value was set greater than 1000 in the Spline Path area on the Path Definition tab in the Scan dialog box.
•PCD-160138 - Fixed an issue where PC-DMIS would hang when you used a RomerRDS arm and distance to target with auto zoom is enabled on the Probe Readouts Setupdialog box.
•PCD-162438 - Corrected an issue where the Remove points with normals outside check box was not available in laser Auto Feature dialog box when the pointcloud was imported as an STL file type. For existing measurement routines, the STL file needs to be re-imported so the normal IJK values are calculated.
•PCD-164330 - Corrected an issue where if you ran PC-DMIS online and opened the Auto Feature dialog box and manually changed the probe position, PC-DMIS didn't show and update the position.
•PCD-165032 - Fixed an F9 issue where datums were added before the FCF command and not after the command.
•PCD-167497 - Fixed the issue when you clicked a button on the Measured Feature toolbar, and your active probe is on a portable arm, PC-DMIS would not create the correct feature type.
•PCD-169815 - Fixed a per-unit Straightness issue that allowed the diameter to report twice.
•PCD-170401 - Fixed an issue where the Edit window cursor was left in an incorrect location.
•PCD-171132 - Fixed a crash that occurred when you deleted the thickness gage from the measurement routine.•PCD-171501 - Corrected an issue where the Surface Profile dimension was not calculated for a Point Colormap.
•PCD-171551 - Fixed an issue where the Autofeature Edge Point (Focus Off) failed to create an edge when you switched on the laser beam with the Laser ON/OFF button in the Probe Toolbox dialog box.
•PCD-171688 - Fixed an issue where the scanner Start/Stop button was not always available on the Tracker Operation toolbar, when the machine was locked on to a laser scanner.
•PCD-172111 - Fixed an issue where the Close button overlapped the text of the Reorder title.
•PCD-173016 - Fixed an issue where some spherical surfaces didn't tessellate correctly.•PCD-173021 - Fixed an issue where the movement of the field of view in the CAD view did not move the machine.
•PCD-173273 - Fixed a crash that occurred when you typed the FCF command and pressed F9 with no features selected.
•PCD-174711 - Fixed an issue where the save operation hangs when you save a large STL file.
•PCD-175456 - Fixed an issue where the feature calculation error occurred though the orange points were shown in the extraction zone when you set the Laser Auto Cylinder horizontal clipping to zero.
•PCD-176095 - Fixed an issue where the Skip and Jumpbuttons were not available in the Execution dialog box when you executed an optical Extended Sheetmetal Feature.
•PCD-177331 - Fixed an issue where the extraction from a pointcloud was incorrect when a few points existed on the radius of a laser auto slot.
•PCD-177379 - Fixed a software crash that occurred when you used Five Unique.
•PCD-177382 - Fixed an issue that caused the nominal values to change to incorrect measurement units when a Size tolerance was entered in an XactMeasure command.
•PCD-177611 - Fixed an issue that showed incorrect intensity values for illumination in the editor.
•PCD-177972 - Corrected an issue where PC-DMIS reported a false warning regarding a "template area" that was not inside the "template search area" when the system had a rotary table at certain angles, such as >90 or <-90.
•PCD-178443 - Corrected a crash that occurred when you selected Undo afteryou chose Edit | OverrideGuess and changed the feature type.
•PCD-179333 - Improved vision feature multi-capture checks for similarillumination between features.
•PCD-179545 - Fixed an issue where the values on the Pointcloud Colormapgradient scale defaulted to three decimal places of accuracy when it wasexpected to be more than three decimal places.
•PCD-180393 - Fixed a software crash that occurred when you used theautocalibrate command with vision and tactile probes on a ring tool.
•PCD-180549 - Fixed a software crash that occurred when you savedmeasurement routines that contained vision features.
•PCD-159016, PCD-179682, and PCD-180650 - Fixed a software crash that occurred whenyou clicked on the expand arrow in the Selected Items list in theXactMeasure GD&T dialog box.
•PCD-180688 - Fixed an issue where values weren't parsed correctly whenXYZ files were imported as CAD.
•PCD-181221 - Fixed an issue where the offline vision CAD camera view didnot work when you renamed the machine HSI.dll.
•PCD-181235 - Fixed an issue where the illumination values were notremembered and synced between software and hardware at startup.
•PCD-181556 - Fixed a software crash that occurred when you cancelled avision probe tip offset calibration where a focus operation was active.
•PCD-181894 - Fixed an issue that corrupted the mouse states and events.
•PCD-182117 - Fixed a delay that occurred when you created Cross Sectionswith a Mesh data object.
•PCD-182992 and PCD-187581 - Fixed an issue where the selection ofmultiple features from Graphic Display window didn't work properly when youcreated an XactMeasure dimension from the XactMeasure dialog box.
•PCD-183181 - Fixed a software crash that occurred when you closed PC-DMIS.
•PCD-183249 - Fixed a software crash that occurred when you pressed theemergency button on arm 1 or arm 2 and the machine goes into anemergency mode.
•PCD-184311 - Fixed an issue where the Quick Feature (Shift + Click) method did not create a Laser Auto Feature because the dense Pointcloud covered the CAD model.
•PCD-184918 - Fixed a Chinese translation issue where a few items were not translated in the Auto Features interface when you turned on the Home Page.
•PCD-184975 - Fixed an issue where the Excel Output labels were not created for dimensions.
•PCD-185104 - Fixed a software crash that occurred when the Test button in the Laser Auto Feature dialog box was used to extract an auto circle from a pointcloud.
•PCD-185347 - Fixed an issue where Edit window failed to print when you select the Prompt option in the Output Configurationdialog box.
•PCD-185388 - Fixed an issue where PC-DMIS would hang with large CAD models.
•PCD-186651 - Fixed an issue with an inconsistency between the segregated points (orange) and the analysis points (green) for Laser Plane auto feature.
•PCD-186691 - Fixed a software crash that occurred when you press the Esc key after you selected the Select Pointcloud option from the QuickCloudtoolbar.
•PCD-186714 - Fixed an issue where scanning circle paths for Adaptive Scan strategies was incorrect.
•PCD-186763 - Added the ONERROR/LASER, SKIPfunctionality to a measurement routine that contains failed ESF (VWMP) commands and is managed as the standard Laser Auto Feature.
•PCD-187016 - Fixed a software crash that occurred when you execute a measurement routine from Inspect that contains a Form command.
•PCD-187179 - Fixed an issue that caused the nominal values to change to incorrect measurement units when a Size tolerance was entered in an XactMeasure command.
•PCD-187266 - Fixed an issue where the QdasData.xml file was broken for the Size dimension.
•PCD-187441 - Fixed an issue where Q-DAS Configurator was not able to read the second and subsequent Size dimension modifiers.
•PCD-187822 - Fixed an issue where the range of Size dimension was not reported in Q-DAS output files
