I'm wondering if there is a command line that can be put in a program to serve the same function as the "enable probe" button on the jogbox?
Enable/Disable probe
It's an SP25. I know what's causing the false trigger and am looking for a workaround because the correct fix would be to replace the machine ! I found the tickbox to "Ignore Motion Errors". Best I can tell, when the box is checked it inserts a command line in the program. When the program is closed and reopened the command line is gone unless I select defaults after ticking the box. I feel this method could be disastrous going forward but will serve my purpose until I can come up with another idea.Sheffield Endeavor3 9.20.8, Tesastar-SM, Leitz LSP-X1s & LSP-X1M, PCDMIS 2011 MR1
by CsmallWe now have the new universal jogbox. My question is: with the old box, I could press both "Enable" and "Run" simultaneously to over...
07-16-2013, 12:26 PM -
by louisdHas anyone else experienced issues conducting a simple 'probe reset' after a movement interruption, while using this probe head? I already submitted...
02-19-2019, 06:15 PM -
by CarlMI have a Brown & Sharpe Micro-Hite CMM. Yesterday as I got uo to leave my foot caught the line to the jogbox and pulled it down onto the floor. Now...
04-20-2011, 09:57 AM -
by WAGSTARWorking on my first PC-DMIS program.
Does anyone know how to disarm the probe while changing
PAA1 auto-joints. I'm generating errors....-
12-04-2007, 10:03 AM -
by BryanI am ising a Shefield Discovery 3 with a Brown & Sharp Pendant 172-194-1
When I press the enable button on the pendant the probe drifts with...-
03-12-2013, 12:08 PM -
