I don't know if there is a more efficient way but this is what I always do....
Go back into the feature by pressing "F9" with your cursor in the code. Then I zoom in on the hit points shown on the Graphic Display and manually change the start hit point to be in the direction I want.
Hope this helps
sigpic I reject your reality and substitute my own
With a positive vector for a hole the normal direction is Major + towards Minor + axis(CCW), reverse the vector and you reverse this. This may cause other issues(as matty pointed out) where manually changing it in the HITS view might be better. I guess it depends on your needs. Why do you care which direction the hits are taken?
I use automove quite a bit so changing the vector is not a suitable fix.
Direction matters when probing threads or when following a contour.
Then manually might be the only way... Probing threads?? why would that matter. If is left hand threads then change the sign of the offset.. I dont understand the contour point..
Well, sometimes I change the pitch from positive to negative for threads. That works for me but you said it didn't work for you. Maybe an 'upgrade' in 4.2. I use 3.7mr3.
Negative pitch number should change the step increment direction, not the direction of rotation.
Yep. So if it is going around a right hand internal thread counterclockwise it should be stepping out of the hole. If not, switching the pitch to the opposite sign should set it straight.
It won't change the hits from clockwise to counterclockwise but it will get the hits incrementing in the proper direction.
do you not probe threads? if probing in the opposite rotation of the pitch you get bad results
have you not followed a contour say like a line,radius,line in a nice flow instead of "jumping up n down" with the probe all the time?
I was in the middle of making a program for a plate that has numerous circles on it. Midway through I must of hit something by accident because now anytime...
