This has happened on a couple of other programs and I have never been able to pin down why it's happening: When measuring a radius (>/= 90 Deg) My direction and start/end angle changes without warning and even the angle changes. Its very frustrating as some of these radii have very limited access or are themselves only 90 deg (so I need to be probing the correct 90 deg. span of the theoretical circle). When it happens, it seems to effect at least all of the partial circles (I didn't notice anything on my full circle measurements though since the direction and start/end angle aren't critical so long as I get 360 deg.) My vectors do not appear to change. Visually, it often looks mirrored about my angle vector BUT that could just be my imagination.
I had not made any alignment changes (to the programs) and the program has executed as initially programmed at least once in all cases.
It appears to be happening from resetting measured values to nominal: However when I tested it, it didn't consistently do it (sometimes it would show mercy to some of my circles)
This time around it occurred 2019R2, Build 362 (SP3), based on my fuzzy memory the previous instances were 2019 R1 or 2018 R2.
