Bestfit Vs Feature Alignments
  • Bestfit Vs Feature Alignments
    Hi,
    I just started doing programming and I have a part I been struggling doing dcc alignments. I have 2 main questions:
    Insight: I am aligning to 2 primary datums (cylinders) which are perpendicular to each other
    1- What is the difference of using bestfit to align the part vs the measured features? I see a difference in the results
    2- How do you prove a program offline and make sure you have a reliable program?
    Thanks for any help.
    In your case, cylinders are only theoritically perpendicular.
    If you use best fit with both cylinders, PC-DMIS ajust all the hits to minimize a parameter (depends on LS, LS vector, minmax...).
    Then, no cylinder axis should fit exactly to an alignment axis.
    If you construct the alignment, you will use a cylinder as primary (level, origin 2 axes), and the second as a rotation. The second axis will be perp to the first.
    The alignment axis and the first cylinder axis will be the same.
    Hope it's clear...
      #2 ?? Reliable program as in " it wont crash at proveout" ? Look at your pathlines and use collision detection ? There are no guarantees and only ways to minimize it. I use 99% clearplanes, in combination with avoidance moves within auto features with a single movepoint at the end of the program. Programming OFFLINE is 100% the way to go. Way faster and your nominals are as perfect as the CAD is. I think I have done 1 program on the CMM in 15 years and the rest have all been done offline.
        Thank you JEFMAN, this helps. In order words
        Schlag
        The alignment : level Cyl1 to Y-axis , translate X and Z to Cyl1, rotate Cyl2 to Z-axis Y to Cyl2. When I create a dimension after the alignment, Cyl1 is showing 0 deviation for x and z-axis, while Cyl2 is showing .0003in deviation in Y-axis.
        To prove out a program shouldn't the deviation be .0000in for x, y, and z?
        Also, I'm programming offline.
        • JEFMAN
          JEFMAN commented
          Create an intersect point between axes, and dimension the distance between point and axes, to check if axes are concurrent.
        Create your alignment but recall" STARTUP" and not another alignment. Make it all fully defined. LEVEL / ROTATE and then lock down x-y-z origin. The x-y-z order doesn't matter but alway LEVEL and then ROTATE in that order. Look at your TRIHEDRON. Is everything locked down ? If everything looks good then you can switch your alignment back to re-calling whatever alignment you want.
          OK. Thanks for the help guys
