We recently switched to version 2017 from 2013. Upon doing so, we noticed we can no longer access the probe changer settings to assign what ports probes are in. We can run programs that use the probe changer without any issue but can't find where to go to edit/modify the probe changer. Tried the PC DMIS help and it says it should be under, edit/preferences/probe changer, but nothing is there. Any suggestions?
Probe Changer ports
Originally posted by louisd View PostYou might need to call hexagon to review your license file permissions. If you converted from HASP to LMS, they likely had to convert your license to the LMS system, and could have omitted privileges.
To check your license got to Help > About PC-DMIS for Windows and it will list all of your available licensesXcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
Run 'Custprog' from your PC-DMIS folder.
That will show you if the 'Tool changer' is an option turned on in your license. If it IS an option, maybe the install was done with a dongle loaded that didn't have it.
If 'Tool changer' is not in your list, go back and find your previous custprog file and make sure it had been there, if it was, hexagon with correct it quickly.
Just had this issue pop up on me...
For future reference, its always a better idea to just install the new rev and leave the old rev in place.
.. for a few days. I've never had two versions reside on the same drive too long before the PC-daemon begins grabbing files from the previous release. usually a probe file from some long ago "I'll just leave the qualification sphere here this time" right when the president of the Company walks in..
and there is always a break in the din of manufacturing, to give complete pause and attention to the Pink - a - Tink, Tinkle of the probe being decapitated and discarding itself on the granite.Last edited by Cumofo; 03-11-2020, 03:07 AM.
by John KuglerLooking for the probe changer drop down. I can't find it. I'm trying to define a probe changer and I can't find the dropdown.
I must...-
09-19-2007, 01:19 PM -
Hi guys, We have an ACR1 probe changer installed on a Giddings & Lewis CORDAX RS-30 DCC using PC-DMIS 2014, but now we want to change to a MCR20....
06-09-2015, 06:31 PM -
by SekharWe have PC-DMIS Cad++ 2013 MR1 in B&S machine. I need to add a probe changer(thinking of buying a probe changer). when I checked in "edit- preference"...
Channel: Tips & Tricks
01-08-2016, 03:58 AM -
by JeditWere not on maintenance & are running V4.2
Can anyone tell me if using a probe changer is a paid option?
If not where do you...-
10-04-2013, 04:06 AM -
We have a Probe Changer ~ We have NO-MENU???
Always found the Probe changer menu under EDIT>PREFERENCES>PROBE CHANGER. It is not...-
10-13-2007, 11:17 AM -
