Flow Control Using Yes/No Issue
  • Flow Control Using Yes/No Issue
    I'm using a series of Yes/No Questions to dictate what is measured and reported vs what is not. My 1st question is essentially "Are all features being measured": If yes, it skips the following questions. The issue is however that when it skips the following questions, their YES/NO answers are still considered later in the program to decide what to skip instead of defaulting to any given value and is effecting the capability of my program. Is there any way for me to get questions that are skipped by If/goto commands to reset to a default value such as yes?
    Edit:
    I figure I can add "IF Q1=Yes, Goto [label immediately after relevant IF Goto command giving me issues]" to fix the issue
    I'm more curious if there are any other ways to accomplish this however, such as but not limited to defaulting to yes for skipped questions
    Well, you could use IF_GoTo command to simplify.
    You could redundantly assign them immediately afterwards, overridiing them to the values you need.
    pseudocode, not exact syntax:
    Allfeat = Comment, yes/no, Are all features being measured"
    c1= Comment, yes/no,
    c2= Comment, yes/no,
    c3= Comment, yes/no,
    If allfeat.input=="YES"
    Assign\C1.input=="NO"
    Assign\C2.input=="NO"
    Assign\C3.input=="NO"
    end_if/
      end_if/
      I'm not sure you can set (write) the input values if comments in that way (I may be wrong) but along the same lines if you initialise some variable you can achieve the same result...
      runall = Comment YES/No - Measure all features
      If runall ==yes
      assign section1 = Yes
      assign section2 = Yes
      assign section3 = Yes
      end if
      goto skipquestions
      c1 = Comment YES/No - Run section1?
      if c1.input==yes
      if c1.input==no
      assign section1= No
      c2 = Comment YES/No - Run section2?
      if c2.input==yes
      if c2.input==no
      assign section2= No
      etc
      Label = skipquestions
      if section1 == yes
      measure stuff here
      end if
      if section2 == yes
      measure stuff here
      end if
      ​​​​​​​etc
      Applications Engineer
      Hexagon UK
      • RandomJerk
        RandomJerk commented
        ^^^ This is the way I'd go, similarly, at least.
        Air code:
        [code]ASSIGN/OP1=0
        ASSIGN/OP2=0
        ASSIGN/OP3=0
        C1= Comment/YESNO, Op1?
        ASSIGN/OP1=IF(C1.input=="YES",1,0)
        {Lather, rinse, repeat}[\code]
        I have a habit of setting variables at the beginning of the program to the safe value even if they'll be evaluated later.
      Use a form and variables rather than the YES/NO questions
        Myself, I would program the features in sections and use IF/GOTO statements. Use an operator INPUT comment to select what is getting checked
        oper/input
        1=thru OPERATION 1
        2=thru OPERATION 2
        3=thru OPERATION 3
        and so on
        10=finished part
        The use the IF/GOTO to skip what isn't being checked.
        The program in REVERSE order (I would) so that FINISHED PART is first, next to last operation is next, and so on, that way it will just run from the "GOTO" label tot he end of the program. This way tends to help avoid PROBE ROTATION issues.
