Help Const.
Make sure the two circles are in the same plane/height/level.
Construct pierce point - select the two circles
If the point ends up at the wrong intersection, flip the direction of one (maybe both) circles and try again.PC-DMIS CAD++ 2o22.1 SP2
- Likes 1
For a "cylinder" I would just do circles/pierce points at multiple heights and construct a line from the pointsPlease Join The Effort.
https://www.pcdmisforum.com/forum/pc...o-metric/page2 (Comment #17)
- Likes 1
Know this is barely legible... but that .21" +/- .030" dimension on the left side of the print is the intersection of those two radii... supposedly....
Channel: PC-DMIS Portable
09-27-2017, 08:37 AM -
is there a way to create the point where the outside diameter of two circles intersect? ...
06-30-2017, 03:32 PM -
by Gagedude127Does anyone know a way to construct an intersection point between two parallel cylinders? Since pc-dmis wants to use the center line of both cylinders...
09-12-2019, 08:46 AM -
by PowerJunkieIs the order in which you take the points for the circles in order to make intersect points important? I can only 'properly' get a point on one correct...
01-11-2019, 02:54 PM -
by mjgman1I have a drawing that ask for the intersection point of 2 radii on a manual machine using pc-dmis 3.5. Can I do this with this version?
06-16-2008, 10:59 AM -
