I have a program that contains a COP command that contains around 2500 points, from the COP I create a surface color map and feed this into a Cad object window in a custom report. I all works perfect, and the report exports with the Color map included.
The program will then finish and the percentage bar to rebuild the edit window executes to about 90% and then the program crashes every time. I know it's the COP and Surface color map as when I remove these items the program executes and doesn't crash.
I think it is a memory or graphics card issue and was wondering had anyone else came across a similar thing and worked out how to fix it. TIA
