Having trouble calibrating a STAR Probe. New PC, Hard Drive, Fresh install of XP SP3, Fresh install of PC-DMIS 4.3 MR2.
1st, I have done this previously on another CMM and it works fine.
2nd, there is no Probe facing down in -Z- on the Star probe setup (not using connection #1). Same on all the CMM's using this setup.
When calibrating the Star probe, the other probes are hitting the sphere instead of clearing it for the probe I am trying to calibrate. Can’t figure out how to move the hits so they aren’t
as deep into the sphere.
After all the usual things like deleting probes, rebuilding, change the PROBE.DAT file, changing the Setup Settings for the probes, nothing works
Re-loaded PC-DMIS 4.2 MR1 with the original part programs it had, does the same thing. It worked before but not now.
