CMM not running at speed set in program
  • CMM not running at speed set in program
    Hi guys,
    I'm having an issue where my CMM seems to be running at max speed rather than the 150 move speed I have all my programs set to. I can shut down the computer and software, reboot, run one part normally then the following runs move at max speed again. Any ideas?
    Did your settings change? Hit F5 and double check if absolute speed is unchecked.
      Why would you slow down the move speed to a crawl ?
      • tking
        tking commented
        Oh, TP. That kinda attitude will get you far here
        Take care, junior!
      • louisd
        louisd commented
        cuz he's not confident in his programming
      • KIRBSTER269
        KIRBSTER269 commented
        I gave you a great big LIKE for your comment, for it was more informative than question that was ask.
      it does sound like you got switched to percent speed and it is running at the max 100% because programming 150% does that. I also did LOL a little at the above comment and thought the same, why run at 150mm/s all the time? if that is what you meant?
      • TPeters1384
        TPeters1384 commented
        I realize now I wrote 150, I had meant to type 250 (not percent). We have an older machine that our company will not put anymore money into so I'm trying to keep her running for awhile.
        Thanks for the insight. I'll look into it.
      Maybe the supercharger is not engaged anymore. Move along
        Dare I ask what is the touch speed you are using?
        • TPeters1384
          touchspeed is at 1.5
        • Douglas
          Douglas commented
          1.5 mm/s is a touch speed for probes so small you break them just by looking at them... that should be bumped up. 1.5% is going to depend on your machine and might be different if that program is ever moved to a different machine... still on the low side though unless small tips
      • ADAM WALLACE
        touch speed clarification
        by ADAM WALLACE
        I have a program running at 75 percent move speed. I need to slow the move speed down from the 75 because of false triggers moving in the z axis of the...
        10-24-2013, 10:23 AM
      • eric_451@hotmail.com
        Slow Machine
        by [email protected]
        !Yet another newbie question!
        We just updated to v.4.2. Since that time my machine has been moving much slower than it was. Is there a speed setting...
        10-02-2007, 03:49 PM
      • AJHVW93
        Move Speed
        by AJHVW93
        Problem When I changed from 3.7mr2 to 3.7mr3 The move speed changed. (The actual speed that is ) Ex 20% of max speed which is 500 in mr2 is slower than...
        07-18-2007, 10:11 AM
      • kweber0000
        Touchspeed Ajustment
        by kweber0000
        Hello again
        I have a advantage 575 ver4.2
        i have tried to change the touchspeed in the program and it has no effect onthe speed...
        08-21-2008, 04:50 PM
      • Jonde1
        Changing move speed?
        by Jonde1
        Is there a way of changing the default speed on our machine? We have just upgraded to Pc-dmis cad++ 2014 and realise that the machine moves a lot slower...
        03-06-2015, 01:22 AM
