The clear planes in my program do not want to co-operate today. I'm using a read point for the manual alignment, as far as I can see I did not forget to translate my Z. DCC_ORG Is a circle that takes 3 sample hits on the Z=0 surface I want. The clearplane at the end is where I'm getting the error.
CODE
CODE
MODE/DCC
CLEARP/ZPLUS,0.15,ZPLUS,0,OFF
MAN_ORG =FEAT/POINT,CARTESIAN
THEO/<-0.787,-0.102,0>,<0,0,1>
ACTL/<16.5346,6.6828,-27.4938>,<0,0,1>
READPOINT/
A_MAN =ALIGNMENT/START,RECALL:STARTUP,LIST=YES
ALIGNMENT/TRANS,ZAXIS,MAN_ORG
ALIGNMENT/TRANS,XAXIS,MAN_ORG
ALIGNMENT/TRANS_OFFSET,XAXIS,0.787
ALIGNMENT/TRANS,YAXIS,MAN_ORG
ALIGNMENT/TRANS_OFFSET,YAXIS,0.102
ALIGNMENT/END
DCC_ORG =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
THEO/<-0.787,-0.102,0>,<0,0,1>,0.096
ACTL/<-0.799,-0.0971,0.0138>,<0.0001931,0.0005264,0.9999998>,0.0 958
TARG/<-0.7874,-0.1023,0>,<0,0,1>
START ANG=0,END ANG=360
ANGLE VEC=<0.8741573,0.4856429,0>
DIRECTION=CCW
SHOW FEATURE PARAMETERS=NO
SHOW CONTACT PARAMETERS=NO
A_DCC =ALIGNMENT/START,RECALL:A_MAN,LIST=YES
ALIGNMENT/TRANS,XAXIS,DCC_ORG
ALIGNMENT/TRANS,YAXIS,DCC_ORG
ALIGNMENT/TRANS,ZAXIS,DCC_ORG
ALIGNMENT/END
DCC_ROT =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
THEO/<-3.898,-0.102,0>,<0,0,1>,0.096
ACTL/<-3.9005,-0.0771,0.001>,<-0.0009519,0.0007254,0.9999993>,0.0953
TARG/<-3.898,-0.102,0>,<0,0,1>
ANGLE VEC=<1,0,0>
DIRECTION=CCW
A_DCC2 =ALIGNMENT/START,RECALL:A_DCC,LIST=YES
ALIGNMENT/ROTATE_CIRCLE,XPLUS,TO,DCC_ROT,AND,DCC_ORG,ABOUT,Z PLUS
ALIGNMENT/END
CHECK/0.05,1
PREHIT/0.04
RETRACT/0.04
DCC_LVL =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,OUTLINE,LEAST_SQR
THEO/<-1.1563,-0.3114,0>,<0,0,1>
ACTL/<-1.1563,-0.3114,0.0002>,<0.0003244,0.0004314,0.9999999>
TARG/<-1.1563,-0.3114,0>,<0,0,1>
ANGLE VEC=<1,0,0>,SQUARE
A_DCC3 =ALIGNMENT/START,RECALL:A_DCC2,LIST=YES
ALIGNMENT/LEVEL,ZPLUS,DCC_LVL
ALIGNMENT/TRANS,ZAXIS,DCC_LVL
ALIGNMENT/END
MOVE/CLEARPLANE
READPOINT/
ALIGNMENT/END
DIRECTION=CCW
ALIGNMENT/END
ANGLE VEC=<1,0,0>
DIRECTION=CCW
ALIGNMENT/END
CHECK/0.05,1
PREHIT/0.04
RETRACT/0.04
ALIGNMENT/END
MOVE/CLEARPLANE
