Hi
I like to ask about help with probe calibration.
Machine Global S with Leitz LSPX1H_T
Problem concerns D4 X 75 probe and PrbRdv field:
Generally my standard procedure is to calibrate all probe from the rack approx. 1 time per week.
I observe that probe D4 X 75 has huge different between calibration from 6 January and 9 January (PrbRdv field)
(All calibration after 9 January showing same problem on this probe.)
Off course I can understand, that something could happened with ball or stem, but I was check that and it looks like physically everything is ok with probe.
Surprising is also, that when I checking all probe on ring gauge with nominal dimension Ø30.997 D4X75 showing results around 0.01 to 0.013mm smaller on diameter. Every other probe showing deviation on diameter ±0.001
At the moment only solution to get proper results is manually changing probe data for each tip… like in below example result after calibration was 0.011, I have change that to 0.0055 to get proper measuring results from ring gauge.
Like I mention before, probe is checked for mechanical damage, ball is sitting fast on stem.
I was also reset all tips, calibrated again nothing help, then probe file was removed and created again, calibrated and still wrong.
I decide to measure ball on this probe like a sphere with new fresh Ø2 and Ø3 probe with 100 hits and result is perfect diameter and roundness:
After calibration assignment ASSIGN/V1=2*(PROBEDATA("DIAMETER")/2+PROBEDATA("PRBRDV")) showing diameter 4.022mm
Maybe you can advise me some other solution? How to verify what is wrong?
