Sometimes i will be running a program that has been perfectly fine running for several days, it will just stop.
No error messages will pop up, the timer will still be counting down, just won't move.
I click to stop everything and try to move the probe with the jog box but it doesn't do anything.
I can still do things in the program but the machine itself will not run and cant get it to move.
The only way i can get it to work again is to power down the computer and then shut down the machine itself, then once i power it back up and everything is loaded back up it will run.
Just today I had this happen to me 4 times and it always stopped in the same spot.
Other times that it has done this its been different spots.
Please help as this is really annoying and a big waste of time. Thank you.
