2020 R1 - setting editor doesn't close.
  • 2020 R1 - setting editor doesn't close.
    When closing the setting editor, the process doesn't close (wait 1 mn before stopping the process in the task manager).
    Does it come from the install, am I alone or is this a bug ?
    Other than that (which is a problem I could live with) - how would you rate 2020, JEFMAN ? Good? Bad?
    PC-DMIS CAD++ 2o23.1
    • JEFMAN
      JEFMAN commented
      Without having CMMVe working, I stopped tests for now...
      For each new version, I begin by testing functionnalities (rotary, vision,laser, calibration, tool changer...)
      In a second time, I test some old progs with a lot of assignments, loops, probes (example : my own vision calibration, which is somewhere here on the forum).
      Then I check some dimensions, and then only, I use it instead of the previous version... It can be long
    • A-machine-insp
      A-machine-insp commented
      I like it. It's gradual improvements from version to version but it does keep getting better.
    Jefman, can you tell me what opereations you might have performed in the Settings Editor before trying to close it? Perhaps this will help us to replicate. Are you changing some values, creating a BACKUP, Reset User, etc?
    Also, try cleaning out this temp folder to see if the issue clears up -
    C:\Users\<user name>\AppData\Local\Temp
    • JEFMAN
      JEFMAN commented
      Didn't change anything
      Happy week-end !
    Hi Don,
    To measure the time, I just opened and closed.
    I'm going to try cleaning up the folder.
    Have a nice week-end, far from coronavirus !
    Jef
      YES. Also the settings editor did not port over my machine settings or personal preferences from 2019, i had to manually import my back-up settings.
        That is odd, which 2019 was it, 2019 R1 or 2019 R2?
          Jwefman, any more details on this? Is it still happening?
            Hi Don,
            After uninstall / re-install, it seems to work.
            CMMVe calibration / focus still don't work.
