report serial number with looping program 4 times
  • report serial number with looping program 4 times
    I am writing a new program to loop 1-4 times for production,
    We save the reports with the serial number n the file name for tractability.
    Start of program****************
    SN1 =COMMENT/INPUT,YES,FULL SCREEN=NO,
    "Serial No1."
    ASSIGN/V6=SN1.INPUT
    end of program********************************
    ASSIGN/V10=SYSTIME()
    COMMENT/REPT,
    V10
    COMMENT/REPT,
    END TIME
    COMMENT/REPT,
    "TIME ="+SYSTEMTIME("HH:mm")
    ASSIGN/V2=ELAPSEDEXECUTIONTIME()
    COMMENT/REPT,
    "RUN TIME= "+V2
    ASSIGN/SVAR="\\\10.99.155.181\usbcifs01\Q\CMM\4062AS105\R EPORTS\SN_"
    ASSIGN/V99=SVAR
    ASSIGN/SVAR=".CSV"
    ASSIGN/V100=SVAR
    ASSIGN/SVAR=".PDF"
    ASSIGN/V101=SVAR
    PRINT/REPORT,EXEC MODE=END,$
    TO_FILE=ON,AUTO=1,AUTO OPEN=OFF,$
    TO_PRINTER=OFF,COPIES=1,$
    TO_DMIS_REPORT=OFF,FILE_OPTION=OVERWRITE,FILENAME= ,$
    TO_EXCEL=ON,AUTO=30,FILENAME=V99+V1+V100,AUTO OPEN=OFF,$
    PREVIOUS_RUNS=KEEP_INSTANCES
    END OF PROGRAM
    This works great for 1 pcs.
    Any ideas on how to do four separate serial numbers and reports.
    Thank you for any help
    Instead of placing that code at the end of the routine, place it before loop/end command.
    • Thomas.Davis
      Thomas.Davis commented
      The loop end is after the code
    This is what I use for a nested loop...it puts a serialized comment at the top of the report.... Maybe you'll find something useful...
     C2 =COMMENT/INPUT,NO,FULL SCREEN=NO,
    <<< Please Enter Beginning Serial Number >>>
    ASSIGN/PARTCOMM=C2.INPUT
    ASSIGN/LOOPPART=PARTCOMM
    C3 =COMMENT/INPUT,NO,FULL SCREEN=NO,
    How Many Parts Are In Each Row? >>>
    ASSIGN/V1=C3.INPUT
    C4 =COMMENT/INPUT,NO,FULL SCREEN=NO,
    <<< How Many Rows? >>>
    ASSIGN/V2=C4.INPUT
    V3 =LOOP/START,ID=YES,NUMBER=V2,START=1,SKIP=,
    OFFSET:XAXIS=0,YAXIS=4,ZAXIS=0,ANGLE=0
    V4 =LOOP/START,ID=YES,NUMBER=V1,START=1,SKIP=,
    OFFSET:XAXIS=4,YAXIS=0,ZAXIS=0,ANGLE=0
    COMMENT/REPT,
    "PART #_"+LOOPPART
      I would assign de serial numbers to measure before the loop with a comment or from, so the program don't have to stop.
      ASSIGN/SERIAL_NUMBER1=SN1.INPUT
      ASSIGN/SERIAL_NUMBER2=SN2.INPUT
      ASSIGN/SERIAL_NUMBER3=SN3.INPUT
      ASSIGN/SERIAL_NUMBER4=SN4.INPUT
      depending on the form of the loop you can use the loop counter or use a teller.
      ASSIGN/TELLER1=1
      V2 =LOOP/START,ID=YES,NUMBER=2,START=1,SKIP=,
      OFFSET:XAXIS=0,YAXIS=875,ZAXIS=0,ANGLE=0
      V1 =LOOP/START,ID=YES,NUMBER=2,START=1,SKIP=,
      OFFSET:XAXIS=350,YAXIS=0,ZAXIS=0,ANGLE=0
      IF/TELLER1==1
      ASSIGN/SERIAL_NUMBER=SERIAL_NUMBER1
      END_IF/
      IF/TELLER1==2
      ASSIGN/SERIAL_NUMBER=SERIAL_NUMBER2
      END_IF/
      IF/TELLER1==3
      ASSIGN/SERIAL_NUMBER=SERIAL_NUMBER3
      END_IF/
      IF/TELLER1==4
      ASSIGN/SERIAL_NUMBER=SERIAL_NUMBER4
      END_IF/
      create the variabele were and with witch name and serial number you want to save the file
      ASSIGN/DOC_NUMMER="C:\\Reports\\1070066081 - MATRIXPLATE_SN_"
      ASSIGN/FILENAME= DOC_NUMMER + SERIAL_NUMBER
      ASSIGN/FILENAME_PDF=FILENAME + ".pdf"
      ASSIGN/FILENAME_EXCEL=FILENAME + ".csv"
      in the first loop the header is placed automaticly, for the other you have to place it.
      IF/TELLER1>1
      REPORT/LABEL, FILENAME= FILE_HEADER.LBL
      END_IF/
      before the loop end you place the print command. Put the variable were and with witch name in the good place.
      Make sure you select DELETE_INSTANCES and use OVERWRITE
      TO_FILE=ON,OVERWRITE=FILENAME_PDF,AUTO OPEN=OFF,$
      TO_EXCEL=ON,OVERWRITE,FILENAME=FILENAME_EXCEL,AUTO OPEN=OFF,$
      ASSIGN/TELLER1=TELLER1 + 1
      LOOP/END
      LOOP/END
