Trying to find out if possible to perform manual scans with this scanner? Have been under the impression that can only operate in DCC and must have CAD model to pick points. Will possibly need to scan stamped process panels for which I will not have CAD to select points from. Thanks
HP-L-10.6 Laser Scanner
It's not possible to manually move the machine with the joystick and scan data. But it's possible to generate scans using the joystick then run them in DCC mode. This is done by creating a linear open scan and using the probe enable button to define your start, direction, and end points for the scan.
The bigger issue is that you're not going to generate any nominal data for the scan to create color maps or measurement data that's not defined on the print without a cad model.
Systems Integrator
by eg92b16a2Good morning,
I am trying to figure out how to do a manual ttp scan. I am on PCDMIS 4.1 with only CAD. Engineering needs me to scan a groove and...-
05-30-2007, 01:29 PM -
by Ken8282When creating a scan is there anyway to create all the points without actually running it when writing the program.
10-17-2012, 11:15 AM -
by norkamusI just learned the versatility of using a grid scan to rain points down on my model. I was wondering what other techniques people have found to gather...
02-23-2016, 03:03 PM -
by russdWe recently acquired a second Global CMM and came across a correlation issue using 2013mr1. It deals with a linear open scan using a TP20. I myself am...
11-12-2014, 02:11 PM -
by TestedI have mirrored a part program and all works well except for the scans. The program jumps right over them "it will not measure them at all"....
01-09-2007, 07:09 AM -
