So I'm having trouble with a few parallelism measurements in a program. It's outputting pretty nonsensical measured values and I can't work out what I've done or not done. Code below for one of the measurements and the features it uses, any suggestions?
Thanks
Thanks
CIR1 =FEAT/CIRCLE,CARTESIAN,IN,LEAST_SQR THEO/<-126.228,51,-128.5>,<-1,0,0>,3 ACTL/<110.776,-463.336,-563.202>,<-0.9999315,-0.0087135,0.0078137>,3.012 MEAS/CIRCLE,5,FEATURE=PLN1 HIT/BASIC,NORMAL,<-126.257,49.573,-128.039>,<0,0.9515913,-0.3073662>,<110.784,-463.718,-561.758>,USE THEO=YES HIT/BASIC,NORMAL,<-126.21,50.708,-127.029>,<0,0.1949228,-0.9808186>,<110.78,-464.841,-562.988>,USE THEO=YES HIT/BASIC,NORMAL,<-126.27,52.413,-127.997>,<0,-0.9421437,-0.3352093>,<110.772,-461.836,-562.987>,USE THEO=YES HIT/BASIC,NORMAL,<-126.169,51.796,-129.771>,<0,-0.5306823,0.8475708>,<110.77,-462.418,-564.389>,USE THEO=YES HIT/BASIC,NORMAL,<-126.236,49.819,-129.425>,<0,0.7873027,0.6165667>,<110.776,-464.37,-564.288>,USE THEO=YES ENDMEAS/ LIN1 =FEAT/LINE,CARTESIAN,UNBOUNDED,NO THEO/<-126.228,51,-128.5>,<1,0,0> ACTL/<110.776,-463.336,-563.202>,<0.9999746,0.0021198,-0.0068067> CONSTR/LINE,BF,3D,CIR1,CIR2,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,WAVELENGTH=0 PLNB =FEAT/PLANE,CARTESIAN,OUTLINE,NO THEO/<-126.228,0,0>,<0,0,1> ACTL/<-125.915,0,0>,<0,0,1> CONSTR/PLANE,PLTO,LIN1,CIR1 DATUMD =FEAT/PLANE,CARTESIAN,OUTLINE,NO THEO/<6.93,54.5,-50.846>,<0,-1,0> ACTL/<6.931,54.404,-50.858>,<-0.0003426,-0.9999848,0.0055063> CONSTR/PLANE,BFRE,PNT1,PNT2,PNT3,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,WAVELENGTH=0 DIM 5.5= PARALLELISM OF PLANE DATUMD,RFS TO PLANE PLNB,RFS UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH AX NOMINAL +TOL -TOL MEAS DEV OUTTOL M 0.000 0.100 0.000 37.209 37.209 37.109 -------->
