I noticed some problems / bugs on V2019 R2 SP3 :
- After a basic scan / plane, the move to clear plane is not perp to the clear plane (if the clear plane is Z, the probe moves on xy of some mm, maybe the tip radius ?)
- The paste / pattern mirror Z worksas a ponctual symetry, not a plane symetry.
- the mirroring doesn't up dte the features contained in a feature set
- feature sets containing hits loose the bracket informations when close the prog (for example, a feature set with CIRC1.HIT[1..CIRC1.NUMHITS] become CIRC1)
- In a loop DO/UNTIL with a alignment inside, I usually assign the alignment name, and save the alignment at the end of the loop and recaal it at the start. In this version, it doesn't work, I have to recall directly the external alignment.
