measuring control points using iterative
  • measuring control points using iterative
    hello
    we usually use fixtures with custom origin offset in the alignement so that the machine recognizes where the points are , but since that i mostly use iterative for other types of measurements , flatness , distance ,etc
    i want to be sure on how can i use iterative to measure control points according to drawing table ,(measuring in free state)
    should i align and select whatever points i want , but this will change the default axis ref (for ex if the top of the part is X i cant make it my z level i guess ) and nominal wont be located in the CAD, I thought of using isostatisme points (or RPS points) in the drawing to align my part , in order to have the x.y.z features as in the drawing then i can just type point nominal in the auto vector and voila you got it ,
    how correct am i ? how do you suggest approaching this
    Many thanks
    up please help
      cmon guys anyone ??
        please
          CHANGE machine to part in F5
            I didn't really under what it is that your having problems with ? maybe attaching a drawing ?
              Do a dcc alignment that calls in the MAIN Datum Structure [-A-][-B-][-C-], [-D-][-E-][-F-] etc.
              Then use the tooling points per drawing for the iterative.
              when done, axis will match your previous alignment and drawing datum structure basics.
