Can you find your happyness ?
ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve...1/Release/x64/
http://software.hexagonmi.com/public...1/Release/x64/
List of Fixes
• PCD-127845 - Fixed an issue where a variable name can be used in the Output Configuration dialog box.
• PCD-155115 - Fixed an issue where PC-DMIS would hang when you tried to move up or down in newly-created assemblies.
• PCD-159846 - Fixed an issue to save the CAD model's hidden status in the snapshot command.
• PCD-161426 - Corrected an issue with GD&T import from JT files where datum A was not generated with the GD&T selection tool.
• PCD-162253 - Corrected an issue where the reference ID for Pointcloud Operators was not used in automation.
• PCD-162438 - Corrected an issue where the Remove points with normals outside check box was not available in laser Auto Feature dialog box when
the pointcloud was imported as an STL file type. For existing measurement routines, the STL file needs to be re-imported so the normal IJK values are calculated.
• PCD-162651 - Fixed an issue for undo and redo function where the Save dialog box does not appear when you had edited the commands in a measurement routine.
• PCD-164330 - Corrected an issue where if you ran PC-DMIS online and opened the Auto Feature dialog box and manually changed the probe position, PC-DMIS didn't show and update the position.
• PCD-164339 - Fixed an issue where both Legacy Perpendicularity and Parallelism displayed an incorrect color representation for the feature material condition size.
• PCD-164342 - Fixed an Expression issue that caused FCFLOC1.TP.MEAS to not report the MEAS value.
• PCD-165032 - Fixed an F9 issue where datums were added before the FCF command and not after the command.
• PCD-165872 - Fixed an Expression issue that caused the variable .m to not report the .m value.
• PCD-168938 - Fixed an application error that occurred when you had used "To Points".
• PCD-169815 - Fixed a per-unit Straightness issue that allowed the diameter to report twice.
• PCD-169834 - Fixed an issue where PC-DMIS didn't allow you to create a QuickFeature whenever the feature size was smaller than the probe diameter.
• PCD-169963 - Fixed an issue in PC-DMIS Vision where the machine would drive off into the air when executing a template matching feature. Now,
when you don't have an actual required camera image, PC-DMIS restricts Template Matching in these ways:
• During execution of a feature with Template Matching, PC-DMIS skips the Template Matching.
• When you edit a feature with Template Matching, PC-DMIS shows the Template Matching, but you cannot edit it.
• When you teach a new feature with the Auto Feature dialog box, PC-DMIS turns off Template Matching, and you cannot turn it on.
• PCD-170088 - Fixed a feature computation error where the laser feature execution did not finish when the feature was skipped.
• PCD-170401 - Fixed an issue where the Edit window cursor was left in an incorrect location.
• PCD-170402 - Fixed an issue where a Mesh Thickness Colormap was not applied when you used selected CAD surfaces.
• PCD-170523 - Fixed an issue where the Laser AF Multiple Creation tab was not available for the Laser Auto Feature Flush and Gap when using a laser probe offline.
• PCD-170533 - Added an ability in the installer to add the LampDefinitions.xml file into the PC-DMIS application directory.
• PCD-171132 - Fixed a crash that occurred when you deleted the thickness gage from the measurement routine.
• PCD-171477 - Fixed an issue where the software stopped responding when you cut a GROUP in the Edit window Summary mode. PC-DMIS now checks for a positive index while accessing a command.
• PCD-171501 - Corrected an issue where the Surface Profile dimension was not calculated for a Point Colormap.
• PCD-171649 - Fixed a crash that occurred when you used the Summary Preview mode in the Edit window and performed a pointcloud alignment.
• PCD-171945 - Fixed an issue where the amount of video RAM was incorrectly reported.
• PCD-172111 - Fixed an issue where the Close button overlapped the text of the Reorder title.
• PCD-172581 - Fixed an issue where the video descriptions on Home Page were cropped in some languages.
• PCD-172591 - Fixed an application error when you used optimize path.
• PCD-172875 - Corrected an issue where sample hits were not handled correctly.
• PCD-173016 - Fixed an issue where some spherical surfaces didn't tessellate correctly.
• PCD-173105 - Fixed a crash that occurred when you selected the Use large menus check box in the Customize dialog box after execution of a measurement routine.
• PCD-173164 - Fixed an application error in Summary Mode (Preview) that occurred when you changed the animation percentage through the F5 settings.
• PCD-173263 - Fixed an issue where the CMM limits used for the collision avoidance during tactile probe calibration with indexable probe heads did not correctly reflect the current active unit. This happened when you opened measurement routines with different units (metric vs inch).
• PCD-173320 - Fixed an issue in multi QuickFeature circle creation where PC-DMIS could not find all the circles. This happened when the circles were colinear and on opposite sides of a flange.
• PCD-173578 - Fixed an issue where PC-DMIS displayed an error when you edited a constructed feature and the input feature is an array.
• PCD-173825 - Fixed an issue with Summary label MEAS and DEV for Position of a Width feature.
• PCD-173826 - Fixed a crash that occurred when you ran the BASIC script file in Summary Mode (Preview).
• PCD-174176 - Fixed an issue where the CAD display state did not match the viewset when a viewset was created.
• PCD-174369 - Fixed an issue where PC-DMIS multiplied the inch value by 25.4 instead of dividing the value when you used the Edge Offset in a Patch scan.
• PCD-174543 - Fixed an issue in the Measurement Strategy Editor where it did not apply the Find Hole setting.
• PCD-174611 - Fixed an issue where Avoidance Move and Surface Thickness parameters were not properly working when you tried to change the values from the MSE widget.
• PCD-174719 - Fixed an issue where annotation points for the Pointcloud Point Colormap were sometimes picked on the back-facing surface. PC-DMIS now picks the points from the current front-facing view.
List of Fixes
