ARC length
  • ARC length
    Its been awhile since using PC-DMIS and I could really use some help.
    I need the ARC length between two points on a radius.
    I scavenged some code from you nice people but dont know whats next.
    I attached a word doc for reference.
    Thanks for any advice. I feel like I need to create a generic feature....
    PT1 =FEAT/POINT,CARTESIAN,NO
    THEO/<42.655,42.657,-0.75>,<-0.7070611,-0.7071525,0>
    ACTL/<42.655,42.657,-0.75>,<-0.7070611,-0.7071525,0>
    CONSTR/POINT,PIERCE,,RAD_FEA
    PT2 =FEAT/POINT,CARTESIAN,NO
    THEO/<-29.968,52.355,-0.75>,<0.496782,-0.8678754,0>
    ACTL/<-29.968,52.355,-0.75>,<0.4965542,-0.8680057,0>
    CONSTR/POINT,PIERCE,RAD_FEA,
    ASSIGN/V1=ABS(PT2.PA-PT1.PA)
    ASSIGN/V2=DEG2RAD(V1)*RAD_FEA.R
    You could create a generic line, with V2 as length, and then dimension the length only.
      To derive the arc length you needs;
      The arc at any length or segment,but projected to a plane normal, but best as a constructed 360 Circle
      A line or for the start arc
      A line for then end arc
      Both projected to the plane normal
      Or
      The arc or cylinder
      One plane start
      One plane end
      Stuff like that. Do you see how pc dmemon wants itz constructions spoon fed to it?
        JEFMAN
        I don't understand how to create a generic line with V2 as the length. For the Generic construction I chose the options listed below.
        >Line
        >Measured Values
        >Polar
        >Independent
        The code generated is shown below
        F1 =GENERIC/LINE,INDEPENDENT,POLAR,$
        NOM/XYZ,<0,0,0>,$
        MEAS/XYZ,<0,29.017,0>,$
        NOM/IJK,<0,0,1>,$
        MEAS/IJK,<0,0,1>,$
        DISTANCE/0,0
        Thanks for any additional suggestions
          I would do it like this :
          Originally posted by GWOLLNER View Post
          JEFMAN
          >Line
          >Measured Values
          >Polar
          >Independent
          F1 =GENERIC/LINE,DEPENDENT,CARTESIAN,$
          NOM/XYZ,<0,0,0>,$
          MEAS/XYZ,<0,0,0>,$
          NOM/IJK,<0,0,1>,$
          MEAS/IJK,<0,0,1>,$
          DISTANCE/V2,V2
            THis is very cool too:
            https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcS3pVasY3chiwpvVErk-rdy1Bka98xFVEXQmuPJw1qACntYgZYa
            See if this will get you started, the math can be done in the demon
            TK
            Example:
              I thought this would be easier. Just trying to help a satellite company. I assumed "dimension the length" from post #2 means use the "Dimension distance", but that clearly isn't working for me.
              PNT14 =FEAT/POINT,CARTESIAN,NO
              CONSTR/POINT,PIERCE,LIN2,RAD_FEA
              PNT15 =FEAT/POINT,CARTESIAN,NO
              CONSTR/POINT,PIERCE,LIN1,RAD_FEA
              ASSIGN/V1=ABS(PNT14.PA-PNT15.PA)
              ASSIGN/V2=DEG1RAD(V1)*RAD_FEA.R
              NOM/XYZ,<0,0,0>,$
              MEAS/XYZ,<0,0,0>,$
              NOM/IJK,<0,0,1>,$
              MEAS/IJK,<0,0,1>,$
              DISTANCE/V2,V2
              DIM DIST1= 2D DISTANCE FROM LINE F1 TO (CENTER TO CENTER),NO_RADIUS UNITS=MM,$
              M 0.000 0.010 0.010 0.000 0.000 0.000 ----#----
              I will go back to the drawing board with this offline seat and try the suggestion from Cumofo.
              Will report back if it works
                I think Cumofo has a strategy that worked for me. When I dimension the radius it pulled the correct nominal. Will know more tomorrow when they try to run execute online.
                Thanks!
                  NOM/XYZ,<0,0,0>,$
                  MEAS/XYZ,<0,0,0>,$
                  NOM/IJK,<0,0,1>,$
                  MEAS/IJK,<0,0,1>,$
                  DISTANCE/V2,V2
                  Dimension the length means "dimension the length" !
                  Use Feature location, then select F1, unselect "auto" and select L (for length !)
                  Hope this helps, you had done the hard part by calculating the length ...
                    Cumofo's post worked for me! Thanks for the help guys!
                    • tking
                      tking commented
                      You're quite welcome
                      TK
                    cant take credit for that. I stole it from T-King.
                    • tking
                      tking commented
                      There's no stealing here, Cumofo! Sharing the joy of life and the pain of the Demon.
                      TK
