rotate to plane?
  • rotate to plane?
    Is it advisable when making an alignment to rotate to a plane.
    I have always used a line.
    ["Paper is poverty,... it is only the ghost of money, and not money itself." --Thomas Jefferson ][/SIGPIC]
    I owuld prefer a line, myself, since it is strictly a 2-D feature. A plane is a 3-D feature and using one for a rotation COULD have some funny results, I would think.
      Done as such
      thanks
        Is rotating to a plane equivalent to rotating to a trace of the plane on the work plane?
          Do it all of the time. Make sure you are picking up a healthy compliment of the plane.
            I take it you have two planar datums.
            Lets say A and B are both planes. Your FCF call out |A|B|C|. Aligning by leveling A and then rotating to B can be tricky. If, however, you level to B and then level to A, the level to A will overide any undesireable rotation to B.
            Or, you could just do as Matt suggests and measure a line on B.
              Or, even intersect the 2 planes.
                Rotating to planes is simple if you control the axis of rotation. So don't ever rotate about an axis you didn't just level to. K?
                  Here also, but it is usually only when the drawing requires it by placing datum targets in areas that would result in a plane.
                  PCDMIS 2012
                  Windows Office XP
                    It is ok to rotate to a plane(as most everyone has pointed out) just do not set an origin to it.
