SCANNING ISSUE.....dealing with the demon
  • SCANNING ISSUE.....dealing with the demon
    I am having an issue with my scan data coming out wavy. I have ran multiple tests to figure out what the problem could be...changed out the probing system, tried multiple stylist sizes, ran different programs to rule out model issues, ran different types of scans that cover all of the machine axes. I also tried changing the exec. control, same result for defined and relearn but normal probing seem to bring back the scan data uniformity. Also my Std.Dev. has jumped up, i normally see around .00001-.00002 across the board no matter what the angle or rotation. Now im getting around .00005-.00006, numbers have never been that high. Not sure if it could be in the controller or if belts could be getting bad. Has anyone encounter this before? Any help on this will be greatly appreciated
    Thanks!
    Machine: B&S Global 7.10.7
    Software: PC-DMIS 2014.1
    Probing System: Renishaw
    This is a reference from one program with how my data normally looks like compared to now.
    NORMAL:
    ISSUE:
    What's your Offset Force set at? .120 is usually a good setting for me. You can also set this in F10
    • mcintyrej
      mcintyrej commented
      Offset force is set to .1; been set at that for years with no issues.
    • KIRBSTER269
      KIRBSTER269 commented
      That seems like a good number, that's just the force that the probe applies on the part..
    You should check the air bearings...
    Just open the hoods, and check if they turn freely.
      Is there a burr bench running or something else that is sending vibrations into the machine?
      7107 Global Classic TP20
      2019R1 SP1 CAD++
      • mcintyrej
        mcintyrej commented
        No, this is my machine i use to build programs and run gages for calibration purposes. Its located in our metrology lab.
      Pull back the dust cover on the "Y" travel, Look where the belt is, check under that bearing and see if you have a pile of metal dust, If so probably needs new bearings everywhere, "Z" and "X" If You do this yourself, you should replace all twelve, it will be a chore. you can get these through McMaster-Carr for about 1.50 a piece. Now if Hexagon does it, If I remember correctly, those bearings are 35.00 a piece, plus labor. This project is not easy to do, so If you go cheap expect problems.
      • mcintyrej
        mcintyrej commented
        Looked at that yesterday and did not see any issues there. Hexagon is coming in to service the machine. Ill update the thread with final verdict for future reference.
        Thanks for your input!
      • KIRBSTER269
        no problem, sometimes a little 3-1 oil on these bearings help. you know what, I can't remember its been awhile when I did this, there might be 4 bearings in each one, now that I think about it.
      • louisd
        louisd commented
        my guess is a dead board in your controller.
      You don't by any chance have filtering or outlier removal turned on, do you? There's some known issues with changing variables within those settings that can contribute to inaccurate/wonky data.
      My first plan of action would be to simplify your baseline. Scan a simple line or plane
      -Second action would be to isolate the machine's drivetrain: scan that simple line or plane, oriented along each axis. See if it is only affected in one or two axis.
      -If so, rotate your probe head B angle 90° and re-attempt. Does it follow the rotated probe head or stick with the machine coords?
      -If you see no contributor to either of those, I would suspect your SP25M is going bad or there's some other issues with your sensor or calibration of it.
      How do your probe calibrations look? How does form of your scanned cal sphere look?
      How does form of your simple plane look if you take a ton of TTP hits on it?
      Not so sure of the SP25M, but the "Probe enable" button on jogbox is a "Probe re-balance" on my leitz, and must be illuminated at all times while measuring. Is this the simple fix, turn on your probe enable button?
        Did you get this sorted?
        It looks a bit like a problem I had a few years ago. In that case, it was solved with a new Logo2 board
        Here's a link to the topic I started on it:
        https://www.pcdmisforum.com/forum/pc...rd-issue/page2
        It has some pics I posted that look a bit like yours, but mine were wavy 'top and bottom' yet smooth on the sides (and I was scanning a XX ring gauge). if I rotated from A0B0 to A0B-90, the waviness went to the sides with smooth top and bottom'.
        Thanks again to louisd, who recommended that last rotation - I was already trying it in A0B0, A90B180, and A90B-90, and getting the same wavy 'top and bottom' in every orientation which seemed to preclude it being a machine axis/travel problem...
        • DB not cooper
          scanning issues
          by DB not cooper
          I'm having an issue and am at a lose on how to fix it.
          I have a program where i'm scanning a line on a groove face, theo's and vectors are...
          11-06-2019, 08:04 PM
        • nooners4
          Perimeter Scan Issue.
          by nooners4
          Hello,
          I am having an issue with a perimeter scan. Please see Images.
          This does not happen on every part. It is intermittent....
          05-30-2017, 07:20 AM
        • ginnbob
          ginnbob
          by ginnbob
          I am doing a line scan of a radius in a hexalobe and then scanning all the way around the hexalobe. I am getting errors for each one. What can I do to...
          11-21-2019, 01:19 PM
        • InspectorD
          Choppy Scan
          by InspectorD
          I'm scanning a compression mold without a cad model using a Leitz scanning probe. It seems that no matter what variables I change the scans keep ending...
          07-29-2015, 02:22 PM
        • Disal
          Another scanning post
          by Disal
          Sorry if this has been talked about before, i honestly didn't find anything that could help. I have a cylinder i'm trying to scan. It has a couple holes...
          11-14-2019, 10:19 AM
