Tooling Ball Alignment on Check Fixture
  • Tooling Ball Alignment on Check Fixture
    I have tried setting up my alignment with the 3 tooling balls on the check fixture but the alignment is showing it is way off from the CAD(up in the air away from the stamping part).
    I use the coordinates from the plaque next to each tooling ball and I'm using the Iterative alignment. I've done the alignment this way before no problems. Please help! Thanks, Andy
    I wouldn't always rely on those numbers being correct....if I were you, I would try and do an iterative alignment of the datums....nets, 2 way 4 way.....then go back and check tolling balls....that should give you some clarity
    Jim Jewell
