Is it possible to move the probehead angles without calibration? I need to measure deep inside the green cylinder using the rotary table (pattern of vector points to construct some circles) but the probe build is too long and I have not enough travel in Z axis, so I need several probe angles to get inside the cylinder step by step (for example, move above and beyond cylinder center with A-75B0, rotate probe angle to A-45B0 and move again beyond cylinder center and so on).
Thanks!
Thanks!
