Cypress Enable Basic to Visual Basic .NET
  • Cypress Enable Basic to Visual Basic .NET
    Does anyone know the correct Visual Basic .NET syntax to replace the Cypress Enable Basic example below?
    Example:
    CommandCount = DmisCommands.Count
    Set DmisCommand = DmisCommands.Item(CommandCount)
    DmisCommands.InsertionPointAfter DmisCommand
    Cypress Enable Basic Example
    Dim DmisApp As Object
    Dim DmisPart As Object
    Dim DmisCommands As Object
    Dim DmisCommand As Object
    Sub Part1
    Set DmisApp = CreateObject("PCDLRN.Application")
    Set DmisPart = DmisApp.ActivePartProgram
    Set DmisCommands = DmisPart.Commands
    End Sub
    Sub Main
    Part1
    DmisPart.RefreshPart
    End Sub
    Visual Basic .NET Example
    Module Module1
    Sub Main()
    Try
    Catch ex As Exception
    MsgBox("PcDmis cannot connect. " & vbNewLine & "(Error - " & ex.Message & ")" & vbNewLine & ex.ToString, MsgBoxStyle.Critical)
    Exit Sub
    End Try
    DmisApp.Visible = True
    'CommandCount = DmisCommands.Count
    'DmisCommand = DmisCommands.Item(CommandCount)
    'DmisCommands.InsertionPointAfter DmisCommand
    End Sub
    End Module
    Working with the Best crashing software like no other.
    PC-DMIS BETA Software
    The CrashRpt Metrology Software company.
    I've yet to figure out how in the world do you get the text to show just like an IDE with colors and such, I love it!
    Dim DmisApp As PCDLRN.Application
    Dim DmisPart As PCDLRN.IPartProgram
    Dim DmisCommands As PCDLRN.Commands
    Dim DmisCommand As PCDLRN.Command
    Try
        Exit Sub
    End Try
    'DmisApp = CreateObject("PCDLRN.Application")
    Dim CommandCount As Integer
    DmisCommand = DmisCommands.Item(CommandCount) ' sets command to very last item
    DmisCommands.InsertionPointAfter(DmisCommand)
    give this a try and please report back if works out for you.
    PcDmis 2015.1 SP10 CAD++
    Global 7-10-7 DC800S
      Kp61dude!, thank you. I will give that a try.
      For the IDE colors, just copy the text from Visual Studio and paste the text to a word document. Then use the Paste from Word Pcdmis Forum Toolbar with Paste from Word.png
      • Kp61dude!
        Kp61dude! commented
        You helped me more than I helped you... thank you!
      That Work Kp61dude!, thank you again.
      Here is a Test example using the information you provide me.
      Module Module1
      Sub Main()
      Try
      DmisApp = CreateObject("PCDLRN.Application") 'Using PCD version 2015.1 10.1 2019.1 15.1
      Exit Sub
      End Try
      DmisCommand = DmisCommands.Add(195, True)
      DmisCommand.Marked = True
      ' Set Destination Expression = V1
      DmisCommand.PutText("V1", PCDLRN.ENUM_FIELD_TYPES.DEST_EXPR, 0)
      ' Set Source Expression = ""Hello""
      DmisCommand.PutText("""Hello""", PCDLRN.ENUM_FIELD_TYPES.SRC_EXPR, 0)
      DmisCommand = DmisCommands.Add(170, True)
      ' Set Id =
      DmisCommand.PutText("", PCDLRN.ENUM_FIELD_TYPES.ID, 0)
      ' Set Comment Type = $$
      DmisCommand.SetToggleString(4, PCDLRN.ENUM_FIELD_TYPES.COMMENT_TYPE, 0)
      ' Set Comment Item 1 = Add BOTTOM sided features, datum definitions and dimensions here:
      DmisCommand.PutText("Add BOTTOM sided features, datum definitions and dimensions here:", PCDLRN.ENUM_FIELD_TYPES.COMMENT_FIELD, 1)
      ' Set Report = NO
      DmisCommand.SetToggleString(1, PCDLRN.ENUM_FIELD_TYPES.OUTPUT_TYPE, 0)
      End Sub
      End Module
      Last edited by Dmisfatboy; 02-20-2020, 09:26 AM. Reason: Added: DmisPart.RefreshPart
        Update: Added Automettech suggestion. Thank you.
        The best thing to do is add a reference to the PC-Dmis type library in your project. That way you get intelisence (or something like that).
        What this means is when you define an object, instead of declaring it as an object you declare it as a specific type of object
        Dim PCDAPP as PCDLRN.Application instead of Dim PCAPP as Object
        Dim PCPart as PCDLRN.PartProgram instead of Dim PCPart as Object
        Now when you type PCDAPP and hit the period "." you get a list of all properties and methods available for that object.
        CODE:
        Code using Visual Studio 2019.
        VB Console App (.NET Framework)
        Module Module1
        Sub Main()
        Try
        Exit Sub
        End Try
        ' Set Source Expression = "Hello"
        ' Set Id =
        ' Set Report = NO
        End Sub
        End Module
        • NinjaBadger
          NinjaBadger commented
          For those that inhabit this and the other forum NinjaBadger=Automettech
        It is best to learn the .Net code for the long run, but in some cases you should be able to just add a couple of ines at the top of the project to make use of your existing (VB6 like) code -
        Imports Microsoft.VisualBasic.ControlChars
        Imports PCDLRN.OBTYPE
        Imports PCDLRN.ENUM_FIELD_TYPES
        Public Class Form1
          Update: Added Don Ruggieri suggestion. Thank you.
          Public Class Form1
          CODE:
          Module Module1
          Sub Main()
          Try
          Exit Sub
          End Try
          DmisCommand = DmisCommands.Add(ASSIGNMENT, True)
          DmisCommand.PutText("V1", DEST_EXPR, 0)
          DmisCommand.PutText("""Hello""", SRC_EXPR, 0)
          DmisCommand = DmisCommands.Add(SET_COMMENT, True)
          ' Set Id =
          DmisCommand.PutText("", ID, 0)
          DmisCommand.SetToggleString(4, COMMENT_TYPE, 0)
          DmisCommand.PutText("Add BOTTOM sided features, datum definitions and dimensions here:", COMMENT_FIELD, 1)
          ' Set Report = NO
          DmisCommand.SetToggleString(1, OUTPUT_TYPE, 0)
          End Sub
          End Module
          • Radar
            Script using Basic
            by Radar
            Where I work we have several parts that only differ as far as the size and number of holes on the face plane of the part. Someone before me has taken...
            12-05-2018, 08:00 PM
          • MrBloondy
            Automated execution of several consecutive programs
            by MrBloondy
            Hi guys.
            I would like to know how i can automate the execution of several consecutive programs and which software i can do it easily.
            Maybe...
            05-15-2016, 05:04 PM
          • Chally72
            Writing/Reading a .txt file
            by Chally72
            This is very much a VB question not related to PC-DMIS. There is so much information out there for VB that I find it very hard to locate a good example...
            09-23-2009, 01:26 PM
          • Rploughe
            Operator Login
            by Rploughe
            here is a basic script for a simple operator login.
            Sub[SIZE=2][COLOR=#000000] Main[/COLOR]
            [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Begin[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][COLOR=#000000] [/COLOR][/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Dialog[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][COLOR=#000000] DIALOG_1 50,10, 300, 125, oOPERATORINPUT[/COLOR]
            GroupBox[/]
            01-21-2014, 01:52 PM
          • Paul Sarrach
            Your SMA not at work:
            by Paul Sarrach
            After I put the call into B&S and called me back the next day, they worked on it for 2 days. And this is thier reply by email no less:
            10-11-2007, 10:37 AM
