PCDMIS 2019 R1 build #375. Customer has hole position requirement (FCF attached). Didn't know what the "P" symbol was and had to investigate. So apparently this hole position is "projected" 3mm above the part. I guess for pins, etc. The problem is that I am not seeing this feature available in the software. Basically, I have Max. Material Cond / Least Material Cond. / Regardless of Feature Size. I am not seeing an option for 'P.' Currently on the ASME 14.5Y standard. Changed to other standards with no effect. PCDMIS doesn't support this? HUSCO FCF.jpg
Hole Position Issue
It doesn't but you can set it up correctly. Use a cylinder to take the hole with then create a plane at the correct offset then create a circle from the circle and the plane.Remembering my beautiful wife Taz who's life was lost on 6-13-2020. I love you and I miss you.
It supports a projected tolerance zone in exacmeasure. Click on the <PZ> toggle after the positional tolerance and choose P. Then type in the distance.153010 Global Advantage w/ LSPX1H_T Analog Probe
7107 Global Classic TP20
2019R1 SP1 CAD++
- Likes 2
Originally posted by RIDER View PostIt supports a projected tolerance zone in exacmeasure. Click on the <PZ> toggle after the positional tolerance and choose P. Then type in the distance.Remembering my beautiful wife Taz who's life was lost on 6-13-2020. I love you and I miss you.
- Likes 1
Um...I am still not getting that option in Xact. In the FCF I am only getting the <MC> option not the <PZ>.
It should be right after the material condition modifier <MC> <PZ>. I don't remember if it was an option in 2012. If it's not there, then you will need to do as A-machine-insp said in post 2.
Measure as cylinder. Also, if you're going to construct it you need to construct an element that extends the entire cylinder and projected zone. So create offset plane, pierce with cylinder, create line from other end of the cylinder to the pierce point, evaluate line. IMHO.
by TestedI've got this call-out
on a hole that goes thru the wall of a cast part that is about 1mm thick. I would normaly check...-
05-04-2007, 07:19 AM -
by ErikirAn engineer for one of our customers is modifying a drawing, and trying to give us as much room for error as possible.
Which of the following...-
04-06-2016, 02:29 PM -
by gdntnoviceCan someone share the manual section on how to program a composite position tolerance. Thanks.
04-17-2020, 12:17 AM -
by kcassadayI'm having a problem understanding how can you call out the position of a hole to the plane in which it resides. For instance, Datum A is the surface...
02-28-2018, 09:39 AM -
by Big RedWhen 'Constructing' a Circle, what is the difference between "Projection" and "Intersect"?
Usually, my true position...-
04-07-2007, 01:15 PM -
