Apply MMC when OS
  • Apply MMC when OS
    Is there a setting to allow MMC on an ID when the feature is oversize?
    Nope. SOL on that one.
      If you want to pass on parts that are out of print just do it. Don't try and get the software to tell you its OK. Just man up and do it.
      • GEllsworth
        MMC -vs- LMC
        by GEllsworth
        I had a discussion with an engineer that MMC should be used for hole diameters and LMC should be used for stud's or O/D parts. He didnt agree and said...
        10-06-2009, 11:57 AM
      • Duckhunter
        MMC ISSUES
        by Duckhunter
        When PC-Dmis is calculating MMC why is it calculating from the top of the tolerance. I though that it should be applied from the 9.7 not the high limit...
        05-12-2006, 05:15 PM
      • kikouyou
        MMC LMC how does it works on the reference?
        by kikouyou
        Why on PCDMIS the MMC is available on not all the features?
        Hi everybody,
        i have a question on the localisation............
        06-13-2009, 05:22 AM
      • Rploughe
        MMC of a Polygon
        by Rploughe
        I have a Hex called out as a datum and an ISR positioned below it. The ISR control frame calls out MMC for it and then calls out MMC for the Hex. How...
        05-01-2014, 05:55 AM
      • simcityguy
        Lmc
        by simcityguy
        I need a good explanation of why I can use bonus on a LMC true position. The customer is telling me I cant do that. Im not sure how to put in words how...
        02-16-2007, 02:53 PM
