True Position in Q-Das
  • True Position in Q-Das
    Hello,
    We has just started using Q-Das at our company. Via the CMM's I have been making the DFQ files, and pumping the database full with the DFQ's.
    Q_Das works everything out, but the true position of holes are showing a larger error than PC_Dmis.
    The holes in question are measured on the CMM. They are at an angle to axis X, Y AND Z, so the option PERPENDCULAR to CENTERLINE is set to ON.
    In the inspection report the holes are within tolerance, but Q_Das shows a larger error.
    The error that Q_Das shows is the same error as PC_Dmis IF the option PERPENDCULAR to CENTERLINE is set to OFF.
    In Q_Das I have looked at the Strategies, it was set to Calculate TP, this is now turned off, but the error's are still there.
    Is there another (standard) Strategy within Q_Das that I can use, that does not calculate the TP?
    Or are we doing something else wrong?
    John
    sigpic If only all problems were so simple
    Are you using polar coordinates in the TP?
    Q_DAS does not calculate for polar correctly, we had to have them right a special script for us but it never worked correctly so we got rid of Q_DAS.
      What if you moved your alignment such that it was translated to the nominal then rotated to be square (all theoreticals/basics, of course), then report TP to 0,0,0?
