Probe build question
  • Probe build question
    I have a probe build 2x20w40ext, can anybody tell me what the
    "NoDraw" means in the picture? My over builds do not have this. Probe 2x20x40.pdf
    Thank you any help on this
    Dennis G
    Using PC-DMIS 2019 R2
    Dennis G............Don't worry Wilson! I'll do all the paddling! You just hang on!---Castaway
    It means its the upper level components will not be visible in your graphic display, it comes in handy when you are try to see if your probe will hit your part or if you need more visibility.
    Double click on the one that say no draw and uncheck or check the box.
      It just means that your picture doesn't show that component. All that is turned on to view is the 40mm extension and the 2x20 probe. Double click on the TP20 and unclick draw and it will be visible.
      7107 Global Classic TP20
      2019R1 SP1 CAD++
        Thank you for the helpful info!
        Dennis G
