In the process of converting to PCDMIS 2019 over the next couple of weeks along with going to WINDOWS 10. But yesterday I went to look at my probe rack and the slot location and for some odd reason I cannot find it in none of the pull down windows. Came in today and reset the controller and computer and still cannot find it im using 2016 now. The IT guy has been backing up files thru settings editor but I didn't notice him changing any settings. Also it still shows that I can change tools that I have in both racks. Stunned
Probe rack missing
Still can't see my probe changer, using the drop down Operation/Calibrate/Edit it doesn't show up. It knows its there from tip changes all day everyday. Is there a option in Settings Editor to turn on or off. I looked and didn't seen any option. I need to change a couple of ports individually a few tenths. STUMPEDsigpic
Originally posted by AuRules View PostStill can't see my probe changer, using the drop down Operation/Calibrate/Edit it doesn't show up. It knows its there from tip changes all day everyday. Is there a option in Settings Editor to turn on or off. I looked and didn't seen any option. I need to change a couple of ports individually a few tenths. STUMPED
Are you saying its not shown at all there in the menu?
or
Are you saying you see these menu choices but they are disabled?
and. . . Do you see the TOOLC.DAT file I mentioned in my earlier post?
- 1 like
Originally posted by Don Ruggieri View Post
When you say you can't see it, let's make a distinction. . . .
or
and. . . Do you see the TOOLC.DAT file I mentioned in my earlier post?sigpic
OK, I know this sounds crazy, but I would try to remove the User files. Back them up first for good practice. This can be done with the Settings Editor. run it, select the BACKUP optopn, and make sure the User radio button is ticked. Once that is done, in the Settings Editor, click on the Reset User (NOT the Reset Product) button.
Alternatively, you can use Windows Explorer. Backup the contents of the folder named "C:\Users\ <user name> \AppData\Local\Hexagon\PC-DMIS\ <version>" and once that is done, remove the contents.
Then try again. Its a long shot, but crazier things have happened.
by 35DodgeWe took ownership of a new Brown & Sharpe 4.5.4 SF it is running PcDmis 2013, with Windows 7. I was given the task of installing an MCR20 probe rack...
02-21-2014, 06:11 PM -
by NMC_CMMAll,
I just installed PCDMIS 2012 and I'm having some probe rack issues.
First off, none of my probe rack location/settings...-
03-30-2013, 12:28 PM -
by KingkrabGlobal 777, DMIS 2014, TP20, 6 slot rack, src20 I think? Standard rack that came with the machine.
I'm the only one using the machine....-
02-24-2015, 06:40 PM -
by stuart mI am working with a Brown & Sharpe one . It has a TESASTARr probe rack. It has worked fine but this morning, I started a program that needed to change...
02-27-2014, 03:29 PM -
by afennerI calibrated my TP20 probe rack and got it working wonderfully. I come back to work today, and it doesn't seem to be activated anymore. I change to a...
06-01-2007, 10:14 AM -
