is there a way to convert an existing measured circle into individual points? i have a profile callout for a circular feature and was hoping to not have to re-create it just for this callout
convert circles to individual points
You can create a cast point of the circle then edit the cast point as below. You will need to create a cast point for every point in the circle (5 point circle = 5 cast points).
PNT1 =FEAT/POINT,CARTESIAN,NO
THEO/<3.3606,-1949.6263,-2020.8902>,<0,0,-1>
ACTL/<3.3606,-1949.6263,-2020.8902>,<0,0,-1>
CONSTR/POINT,CAST,CIR1.HIT[1]PNT100 =FEAT/POINT,CARTESIAN,NO
CONSTR/POINT,CAST,CIR1.HIT[1]DeWain Hodge
If you programmed to the correct basics, you should just be able to ask for the profile of the circle. Double check that it's taking all the individual hits by turning on TEXT.
IIRC, as soon as you add a second feature it stops looking at the hits and looks at the derived centers.
If it doesn't work, and your nominals are correct, create a scanset out of the hits like such:
Code:CIR1 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR THEO/<-0.03,-0.052,-0.0669>,<0,0,1>,0.1587 ACTL/<-0.03,-0.052,-0.0669>,<0,0,1>,0.1587 TARG/<-0.03,-0.052,-0.0669>,<0,0,1> START ANG=0,END ANG=0 ANGLE VEC=<1,0,0> DIRECTION=CCW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES NUMHITS=100,DEPTH=0.0787,PITCH=0 SAMPLE METHOD=SAMPLE_HITS SAMPLE HITS=0,SPACER=0 AVOIDANCE MOVE=NO,DISTANCE=0.3937 FIND HOLE=DISABLED,ONERROR=NO,READ POS=NO SHOW HITS=NO SCN1 =FEAT/SET,CARTESIAN THEO/<-0.0199,0.0151,0.0039>,<0,0,1> ACTL/<-0.0199,0.0151,0.0039>,<0,0,1> CONSTR/SET,BASIC,CIR1.[SIZE=14px][B]HIT[1..CIR1.NUMHITS][/B][/SIZE],,
- 2 likes
What I am working on is a test for an upcoming part. The part will have seal grooves in it and I know I can use points without an issue but I am wanting...
01-27-2021, 09:00 AM -
by gt143744More of a vision question but that forum is dead. Is there a way to get two arcs of the same diameter and create/report them as one diameter? I have two...
01-28-2021, 08:23 AM -
by Tito81Not sure why CMM stops in the middle of the program while the probe inside a hole without any messages or errors. any ideas what is going on here?...
08-27-2019, 06:02 AM -
by ncsteinbWe make a lot of camshafts here, where I need to scan an OD from two directions. I've created one Adaptive Circle Scan (FEAT_98_A) which goes from say...
03-17-2021, 09:47 AM -
by djohnsonOK. I created an auto circle around the outside and inside of a lid. Is there a way I can make the hit points used in creating the auto circle, individual...
03-08-2016, 02:36 PM -
