true position question
  • true position question
    When I report true position in Xact and compare to legacy my position is out of tolerance the same amount which is a crazy number....but when I report the location of the diameter i am within .0015 X Y.... is there a chance pcdmis is.... calculating position incorrectly because .050 seems a bit much.. Thank you
    Lets see some pics of these results, are your X and Y's the same? Blind leading the blind
      the x and y are the same when I report xact and legacy... but when use location they are very close..
      i dont know how to post pictures im sorry..
      In the past when I had this issue it was because of my alignment... in this instance i am confident it is not my alignment..
        What are your datums? Is your legacy alignment datums and the datums you define for Xact the same?
        Post some code?
          how do you post code again?
            [code]
            tip/t1a90b0, shankijk=0, 1, 0, angle=180
            pln1 =feat/plane,cartesian,triangle
            theo/<-1,0.1512,0.0368>,<-1,0,0>
            actl/<9.6775,31.3934,-22.8045>,<0.0001301,0.9999997,0.0007024>
            meas/plane,3
            hit/basic,normal,<-1,-1.2273,0.0725>,<-1,0,0>,<9.5009,31.3924,-21.3637>,use theo=yes
            hit/basic,normal,<-1,0.817,-0.8811>,<-1,0,0>,<10.8472,31.3941,-24.0238>,use theo=yes
            hit/basic,normal,<-1,0.864,0.919>,<-1,0,0>,<8.6844,31.3937,-23.0262>,use theo=yes
            endmeas/
            a1 =alignment/start,recall:startup,list=yes
            alignment/level,yplus,pln1
            alignment/end
            workplane/yplus
            cir1 =feat/circle,cartesian,out,least_sqr
            theo/<0,0.4059,0>,<0,1,0>,3.629,0
            actl/<9.9143,30.9044,-22.9709>,<0,1,0>,3.6288,0
            meas/circle,3,yplus
            hit/basic,normal,<-1.7926,0.4044,-0.2812>,<-0.9879202,0,-0.1549637>,<8.7539,30.905,-21.5761>,use theo=yes
            move/circular
            hit/basic,normal,<0.8418,0.371,1.6074>,<0.4639343,0,0. 8858696>,<8.684,30.9034,-24.3045>,use theo=yes
            move/circular
            hit/basic,normal,<-0.1304,0.4424,-1.8098>,<-0.0718575,0,-0.9974149>,<11.7286,30.9047,-22.9844>,use theo=yes
            endmeas/
            tip/t1a0b0, shankijk=0, 0, 1, angle=-90
            lin1 =feat/line,cartesian,unbounded
            theo/<-1.3154,-8.2045,-4.4233>,<0.0007024,0,0.9999998>
            actl/<5.4249,22.1542,-21.6325>,<0.9999931,0,0.0037028>
            meas/line,2,yplus
            hit/basic,normal,<-1.3154,-7.1083,-4.4233>,<-0.9999998,0,0.0007024>,<5.4249,23.2482,-21.6325>,use theo=yes
            hit/basic,normal,<-1.3092,-9.3007,4.4915>,<-0.9999998,0,0.0007024>,<14.4582,21.0603,-21.599>,use theo=yes
            endmeas/
            a2 =alignment/start,recall:a1,list=yes
            alignment/rotate,xplus,to,lin1,about,yplus
            alignment/trans,xaxis,cir1
            alignment/trans,zaxis,cir1
            alignment/trans,yaxis,pln1
            alignment/end
            mode/dcc
            tip/t1a90b0, shankijk=0.0045, 1, -0.0011, angle=-179.7635
            move/point,normal,<0.3239,3.0312,12.2977>
            pnt1 =feat/contact/vector point/default,cartesian
            theo/<-0.0146,0,1.3833>,<0,1,0>
            actl/<-0.0146,0.0002,1.3829>,<0,1,0>
            targ/<-0.0146,0,1.3833>,<0,1,0>
            snap=no
            show feature parameters=no
            show contact parameters=yes
            avoidance move=no,distance=0.5
            show hits=no
            pnt2 =feat/contact/vector point/default,cartesian
            theo/<-1.2282,0,-0.025>,<0,1,0>
            actl/<-1.2286,0.0002,-0.0253>,<0,1,0>
            targ/<-1.2282,0,-0.025>,<0,1,0>
            snap=no
            show hits=no
            pnt3 =feat/contact/vector point/default,cartesian
            theo/<-0.0345,0,-1.272>,<0,1,0>
            actl/<-0.0342,0.0003,-1.2723>,<0,1,0>
            targ/<-0.0345,0,-1.272>,<0,1,0>
            snap=no
            show hits=no
            pnt4 =feat/contact/vector point/default,cartesian
            theo/<1.2692,0,-0.0746>,<0,1,0>
            actl/<1.2694,0,-0.0747>,<0,1,0>
            targ/<1.2692,0,-0.0746>,<0,1,0>
            snap=no
            show hits=no
            pln2 =feat/plane,cartesian,outline,no
            theo/<-0.002,0,0.0029>,<0,1,0>
            actl/<-0.002,0.0002,0.0027>,<0.0000686,1,0.0000221>
            constr/plane,bf,pnt1,pnt2,pnt3,pnt4,,
            outlier_removal/off,3
            filter/off,wavelength=0
            cyl_datum_c=feat/contact/cylinder/default,cartesian,out,least_sqr
            theo/<0,-0.15,0>,<0,1,0>,3.629,-1.25
            actl/<0.0001,-0.15,-0.0006>,<-0.0000086,1,-0.0000296>,3.6291,-1.25
            targ/<0,-0.15,0>,<0,1,0>
            start ang=286.3,end ang=286.3
            angle vec=<1,0,0>
            direction=ccw
            numhits=11,numlevels=3,depth=0.25,end offset=0.328,pitch=0
            sample method=sample_hits
            sample hits=0,spacer=0
            avoidance move=before,distance=0.5
            find hole=disabled,onerror=no,read pos=no
            show hits=no
            move/point,normal,<-0.0407,-0.0527,5.3869>
            tip/t1a90b-105, shankijk=0.9647, -0.2632, -0.0037, angle=-90.0662
            move/point,normal,<7.5214,-11.4966,5.3653>
            pnt5 =feat/contact/vector point/default,cartesian
            theo/<6.5458,-10.9756,1.0675>,<0.9708951,-0.2395053,0>
            actl/<6.547,-10.9763,1.0671>,<0.9708951,-0.2395053,0>
            targ/<6.5458,-10.9756,1.0675>,<0.9708951,-0.2395053,0>
            snap=no
            show hits=no
            pnt6 =feat/contact/vector point/default,cartesian
            theo/<6.8369,-9.7953,-0.0206>,<0.9708951,-0.2395053,0>
            actl/<6.8376,-9.7955,-0.0209>,<0.9708951,-0.2395053,0>
            targ/<6.8369,-9.7953,-0.0206>,<0.9708951,-0.2395053,0>
            snap=no
            show hits=no
            pnt7 =feat/contact/vector point/default,cartesian
            theo/<6.5806,-10.8345,-1.0395>,<0.9708951,-0.2395053,0>
            actl/<6.5807,-10.835,-1.0399>,<0.9708951,-0.2395053,0>
            targ/<6.5806,-10.8345,-1.0395>,<0.9708951,-0.2395053,0>
            snap=no
            show hits=no
            pnt8 =feat/contact/vector point/default,cartesian
            theo/<6.3114,-11.9257,-0.1079>,<0.9708951,-0.2395053,0>
            actl/<6.3118,-11.9265,-0.108>,<0.9708951,-0.2395053,0>
            targ/<6.3114,-11.9257,-0.1079>,<0.9708951,-0.2395053,0>
            snap=no
            show hits=no
            pln_datum_f=feat/plane,cartesian,outline,no
            theo/<6.5687,-10.8828,-0.0251>,<0.9708951,-0.2395053,0>
            actl/<6.5693,-10.8833,-0.0254>,<0.9708876,-0.2395349,-0.0005582>
            constr/plane,bf,pnt5,pnt6,pnt7,pnt8,,
            cyl_datum_h=feat/contact/cylinder/default,cartesian,in,least_sqr
            theo/<6.5499,-10.8336,-0.0002>,<0.9708951,-0.2395053,0>,1.56,4.38
            actl/<6.5499,-10.8335,-0.0048>,<0.9708978,-0.2394932,-0.000733>,1.5601,4.38
            targ/<6.5499,-10.8336,-0.0002>,<0.9708951,-0.2395053,0>
            start ang=0,end ang=360
            angle vec=<-0.2395053,-0.9708951,0>
            direction=ccw
            numhits=11,numlevels=3,depth=0.1,end offset=4,pitch=0
            avoidance move=both,distance=0.5
            show hits=no
            move/point,normal,<7.5212,-11.4967,5.3652>
            tip/t1a90b75, shankijk=-0.9647, 0.2632, 0.0037, angle=90.0662
            move/point,normal,<-8.1045,-9.1648,5.4365>
            pnt9 =feat/contact/vector point/default,cartesian
            theo/<-7.1746,-10.4852,1.0665>,<-0.9708951,0.2395053,0>
            actl/<-7.1747,-10.4851,1.0662>,<-0.9708951,0.2395053,0>
            targ/<-7.1746,-10.4852,1.0665>,<-0.9708951,0.2395053,0>
            snap=no
            show hits=no
            pnt10 =feat/contact/vector point/default,cartesian
            theo/<-6.7435,-8.7375,1.0249>,<-0.9708951,0.2395053,0>
            actl/<-6.7434,-8.7374,1.0246>,<-0.9708951,0.2395053,0>
            targ/<-6.7435,-8.7375,1.0249>,<-0.9708951,0.2395053,0>
            snap=no
            show hits=no
            pnt11 =feat/contact/vector point/default,cartesian
            theo/<-6.3096,-6.9785,0.855>,<-0.9708951,0.2395053,0>
            actl/<-6.3094,-6.9785,0.8546>,<-0.9708951,0.2395053,0>
            targ/<-6.3096,-6.9785,0.855>,<-0.9708951,0.2395053,0>
            snap=no
            show hits=no
            pnt12 =feat/contact/vector point/default,cartesian
            theo/<-6.4536,-7.5624,-1.0588>,<-0.9708951,0.2395053,0>
            actl/<-6.4547,-7.5621,-1.0592>,<-0.9708951,0.2395053,0>
            targ/<-6.4536,-7.5624,-1.0588>,<-0.9708951,0.2395053,0>
            snap=no
            show hits=no
            pnt13 =feat/contact/vector point/default,cartesian
            theo/<-6.8826,-9.3015,0.0801>,<-0.9708951,0.2395053,0>
            actl/<-6.883,-9.3015,0.0801>,<-0.9708951,0.2395053,0>
            targ/<-6.8826,-9.3015,0.0801>,<-0.9708951,0.2395053,0>
            snap=no
            show hits=no
            pln4 =feat/plane,cartesian,outline,no
            theo/<-6.7128,-8.613,0.3935>,<-0.9708951,0.2395053,0>
            actl/<-6.713,-8.6129,0.3933>,<-0.9708785,0.2395718,0.0005653>
            constr/plane,bf,pnt9,pnt10,pnt11,pnt12,pnt13,,
            cyl_2 =feat/contact/cylinder/default,cartesian,in,least_sqr
            theo/<-6.4392,-7.6294,-0.0002>,<-0.9708951,0.2395053,0>,1.56,4.38
            actl/<-6.4391,-7.6289,0.0039>,<-0.9708616,0.2396406,0.0004387>,1.5602,4.38
            targ/<-6.4392,-7.6294,-0.0002>,<-0.9708951,0.2395053,0>
            angle vec=<0.2395053,0.9708951,0>
            direction=ccw
            show hits=no
            pnt14 =feat/point,cartesian,no
            theo/<-6.4684,-7.6222,-0.0002>,<-0.9708951,0.2395053,0>
            actl/<-6.4687,-7.6217,0.004>,<-0.9708616,0.2396406,0.0004387>
            constr/point,pierce,pln4,cyl_2
            pnt15 =feat/point,cartesian,no
            theo/<6.579,-10.8408,-0.0002>,<0.9708951,-0.2395053,0>
            actl/<6.5798,-10.8408,-0.0048>,<0.9708978,-0.2394932,-0.000733>
            constr/point,pierce,pln_datum_f,cyl_datum_h
            pnt16 =feat/point,cartesian,no
            theo/<0,0,0>,<0,1,0>
            actl/<0.0001,0.0002,-0.0006>,<-0.0000086,1,-0.0000296>
            constr/point,pierce,pln2,cyl_datum_c
            pln_datum_d=feat/plane,cartesian,outline,yes
            theo/<0,0,0>,<0,0,1>
            actl/<0.0371,-6.1541,-0.0005>,<0.0006799,0.0000227,0.9999998>
            constr/plane,bf,pnt14,pnt15,pnt16,,
            lin_datum_e=feat/line,cartesian,unbounded,no
            theo/<-6.4684,-7.6222,-0.0002>,<0.9708951,-0.2395053,0>
            actl/<-6.4687,-7.6217,0.004>,<0.9708889,-0.2395293,-0.0006547>
            constr/line,bf,3d,pnt14,pnt15,,
            pnt_intersection=feat/point,cartesian,no
            theo/<0,-9.2179,-0.0001>,<0,1,0>
            actl/<0.0001,-9.2176,-0.0004>,<-0.0000086,1,-0.0000296>
            constr/point,int,cyl_datum_c,lin_datum_e
            a3 =alignment/start,recall:a2,list=yes
            alignment/level,zplus,pln_datum_d
            alignment/rotate,yplus,to,cyl_datum_c,about,zplus
            alignment/trans,yaxis,pnt_intersection
            alignment/trans,zaxis,pln_datum_d
            alignment/trans,xaxis,cyl_datum_c
            alignment/end[code]
              Just cleaned up the code a little bit.
              alignment/end
              workplane/yplus
              alignment/end
              mode/dcc
              alignment/end
                theres more but thats all the code up to my dcc alignment,,,, thank you for cleaning that up for me
                  cyl_datum_h, pln_datum_f and lin_datum_e have the same theo vector, and pln and cyl have very close theo coordinates.
                  Without seeing the print, I can be wrong, but I think it's strange.
                  I would check differences between datums references and alignment.
                    Give us a snippet, open up Snipping Tool. Select the area to take save it to your Desktop easy to find. Click on the A button, then click on Upload Attachments, find for snippet, better if it's a JPeg. Click on Large and then Post Reply.
                      my part is basically a cross thats slanted..... DATUM H is the right side bore of the cross.... DATUM F is the face of DATUM H... and DATUM E is the other side of the cross through to datum H.....Hope this makes sense.....
                          hopefully this helps clarify...to show all the datums.... C and D are strange so I used the bore for C and constructed intersection points to construct datum D
                              How log is the bore for C ? Is that a casting ? If C is really short I would consider using the larger OD surface for leveling and then 0.000 on the bore for x -y or z. Depending on machine process I do that for a bunch of parts we do. Bore is really short be we do concentric bore on opposite end of part and then hold it from both ends, like turning between centers. I make a compound datum from both bores. Only 1 end is the print datum but its so short it alway told me my feaures along the length were" wandering" off the part. Indicator would tell me I am withing .0005. Change to this datum structure the CMM matched the indicator flawlessly. Yeah, I know the print says.....blah blah
