I'm running a 5 piece 100% inspection (or is it called layout?). On the first 2 pieces, the TP was within tolerance but for the last 3 pieces, the TP is 0. I find this odd. Would someone please check the code for me to see if I am programming this incorrectly or if the parts are actually solid?
Thanks.
Thanks.
PLN1 =FEAT/PLANE,CARTESIAN,TRIANGLE THEO/<-0.3379,2.9281,0>,<0,0,1> ACTL/<56.6969,47.2561,-600.8236>,<0.0011703,-0.0000505,0.9999993> MEAS/PLANE,3 HIT/BASIC,NORMAL,<20.7984,1.481,0>,<0,0,1>,<77.6732,46 .8856,-600.8481>,USE THEO=YES HIT/BASIC,NORMAL,<-8.579,20.1156,0>,<0,0,1>,<46.1042,65.7948,-600.8102>,USE THEO=YES HIT/BASIC,NORMAL,<-13.233,-12.8124,0>,<0,0,1>,<46.3134,29.0879,-600.8123>,USE THEO=YES ENDMEAS/ CIR1 =FEAT/CIRCLE,CARTESIAN,OUT,LEAST_SQR THEO/<0,0,1.2313>,<-0.0013721,0.0002556,0.999999>,78.0918,0 ACTL/<55.2107,46.7364,-599.4994>,<0,0,1>,78.0735,0 MEAS/CIRCLE,3,ZPLUS HIT/BASIC,NORMAL,<-23.7967,-30.9563,1.132>,<-0.6094578,-0.7928183,-0.0006336>,<39.0732,11.1914,-599.8673>,USE THEO=YES MOVE/CIRCULAR HIT/BASIC,NORMAL,<-11.7441,37.238,1.401>,<-0.300771,0.9536962,-0.0006564>,<26.9566,73.673,-599.4029>,USE THEO=YES MOVE/CIRCULAR HIT/BASIC,NORMAL,<39.0393,0.7267,1.164>,<0.9998259,0.0 186118,0.0013671>,<94.2466,46.9963,-599.2279>,USE THEO=YES ENDMEAS/ PNT1 =FEAT/POINT,CARTESIAN THEO/<39.0425,0.5246,1.0503>,<0.9999991,0,0.0013721> ACTL/<94.2453,46.9945,-599.6437>,<0.999751,0.0222892,0.0010873> MEAS/POINT,1,WORKPLANE HIT/BASIC,NORMAL,<39.0425,0.5246,1.0503>,<0.9999991,0, 0.0013721>,<94.2453,46.9945,-599.6437>,USE THEO=YES ENDMEAS/ A1 =ALIGNMENT/START,RECALL:STARTUP,LIST=YES ALIGNMENT/LEVEL,ZPLUS,PLN1 ALIGNMENT/TRANS,ZAXIS,PLN1 ALIGNMENT/TRANS,XAXIS,CIR1 ALIGNMENT/TRANS,YAXIS,CIR1 ALIGNMENT/ROTATE,XPLUS,TO,PNT1,ABOUT,ZPLUS ALIGNMENT/END MODE/DCC CLEARP/ZPLUS,10,ZPLUS,0,ON PREHIT/5 RETRACT/2 MOVE/CLEARPLANE PLN2 =FEAT/PLANE,CARTESIAN,TRIANGLE THEO/<-3.3467,1.0365,-0.005>,<0.0001454,0.0004066,0.9999999> ACTL/<-3.3481,1.0324,0.0044>,<0.000329,0.0002901,0.999999 9> MEAS/PLANE,3 HIT/BASIC,NORMAL,<15.7227,0.5496,-0.0076>,<0.0001454,0.0004066,0.9999999>,<15.7219,0 .545,-0.0017>,USE THEO=YES HIT/BASIC,NORMAL,<-14.9081,18.1692,-0.0103>,<0.0001454,0.0004066,0.9999999>,<-14.9095,18.1656,0.0033>,USE THEO=YES HIT/BASIC,NORMAL,<-10.8548,-15.6094,0.0028>,<0.0001454,0.0004066,0.9999999>,<-10.8568,-15.6134,0.0117>,USE THEO=YES ENDMEAS/ DATDEF/FEATURE=PLN2,A MOVE/CLEARPLANE CIR2 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,OUT,LEAST_SQR THEO/<0,0,-0.1>,<0,0,1>,78.085,0 ACTL/<0.0011,-0.002,-0.1>,<0,0,1>,78.074,0 TARG/<0,0,-0.1>,<0,0,1> START ANG=0,END ANG=360 ANGLE VEC=<0.9973254,-0.0730888,0> DIRECTION=CCW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES NUMHITS=7,DEPTH=1,PITCH=0 SAMPLE METHOD=SAMPLE_HITS SAMPLE HITS=0,SPACER=0 AVOIDANCE MOVE=NO,DISTANCE=0 FIND HOLE=DISABLED,ONERROR=NO,READ POS=NO SHOW HITS=NO MOVE/CLEARPLANE DATDEF/FEATURE=CIR2,B PNT2 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN THEO/<39.0423,0,1>,<0.9999958,0.0029093,0> ACTL/<39.0394,-0.002,1.0008>,<0.9999958,0.0029093,0> TARG/<39.0423,0,1>,<0.9999958,0.0029093,0> SNAP=NO SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES AVOIDANCE MOVE=NO,DISTANCE=1.778 SHOW HITS=NO MOVE/CLEARPLANE A2 =ALIGNMENT/START,RECALL:A1,LIST=YES ALIGNMENT/LEVEL,ZPLUS,PLN2 ALIGNMENT/TRANS,ZAXIS,PLN2 ALIGNMENT/TRANS,XAXIS,CIR2 ALIGNMENT/TRANS,YAXIS,CIR2 ALIGNMENT/ROTATE,XPLUS,TO,PNT2,ABOUT,ZPLUS ALIGNMENT/END CIR3 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,OUT,LEAST_SQR THEO/<-0.0009,-0.0024,3.5>,<-0.0001466,-0.0004062,0.9999999>,74,0 ACTL/<-0.0005,-0.0019,3.5>,<-0.0001466,-0.0004062,0.9999999>,74.0352,0 TARG/<-0.0009,-0.0024,3.5>,<-0.0001466,-0.0004062,0.9999999> START ANG=0,END ANG=360 ANGLE VEC=<0.9999958,-0.0029093,0.0001454> DIRECTION=CCW SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=YES NUMHITS=7,DEPTH=1,PITCH=0 SAMPLE METHOD=SAMPLE_HITS SAMPLE HITS=0,SPACER=0 AVOIDANCE MOVE=NO,DISTANCE=0 FIND HOLE=DISABLED,ONERROR=NO,READ POS=NO SHOW HITS=NO FCFLOC2 =POSITION : CIR3 FEATCTRLFRAME/SHOWNOMS=NO,SHOWPARAMS=NO,SHOWEXPANDED=NO SIZE TOLERANCES/1,DIAMETER,74,0.13,0.13 PRIMARY DIMENSION/POSITION,DIAMETER,0.2, ,A,B, NOTE/FCFLOC2 FEATURES/CIR3,,
