This seems like a stupid question, but I cannot seem to find the XACTMEASURE GD&T dialog box anywhere in PCDMIS (2014) after establishing my datums (Insert > Dimension > Datum Definition). If anyone would please be kind enough to share with me as to where it is, I would appreciate it. Thank you.
XACTMEASURE GD&T Dialog Box
Insert > Dimension > Choose a geometric characteristic. Make sure "Use Legacy Dimensions" is not selected.
ALousyUser Just a tip - You can also get to your datum definition dialog through any of the XactMeasure Dialogs.
by MiloradRecently I am installed 2010 MR2 version and I have a problem, more or less, with all GD&T dimensions, (Position, Circularity, Flatness . . et.)....
05-21-2011, 11:29 AM -
by SAM-IMCHello all, I am having my first try at an angularity call out. I couldn't get it to work so i looked in the HELP file and the dialog box that the HELP...
04-26-2012, 04:19 PM -
by Rush2112In the advanced tab on the xactmeasure, my "fit to datums" box is checked but also inactive (greyed out) so i cant uncheck it. how can i make...
09-20-2017, 02:55 PM -
by pwhitsaA question for you exactmeasure guru's out there:
Is it possible to use a constructed feature set as a valid datum in exactmeasure?
04-04-2014, 03:21 AM -
by Jason RoseHi,
I changed jobs and my new company has the exact same PCDMIS program as the old company. However, when I go to the GD&T dialogue boxes...-
08-06-2019, 07:42 PM -
