Circular Moves Toggle Diameter Change Possible?
  • Circular Moves Toggle Diameter Change Possible?
    I've got a circular part with several notches/tabs sticking out. I'm trying to DCC measure the auto circle (OD) right below those same tabs. However, I cannot seem to change the circular moves toggle diameter so it'll clear the tabs before moving onto the next hit, no matter what I do. Is it possible to make the circular moves toggle bigger?
    I'm running PCDMIS 2014 if anyone is wondering.
    You can't. It circular moves at the PREHIT distance, so crack that up for the feature.
    • ALousyUser
      ALousyUser commented
      Ah, that makes sense. Thanks a ton!
    • louisd
      louisd commented
      don't forget to marry it with RETRACT.
    Also, if you do not need a large prehit/retract for all of the hits, only a few, you can add clearplanes or move points in between the desired hits by showing hit parameters, showing hits, and insert your move point between the desired hits. I would recommend keeping the show hits toggle set to ON if you do this, otherwise someone could easily miss it in the future.
    • ALousyUser
      That's really helpful. I wasn't aware I could see my hits when using auto features after exiting the Edit window. This is awesome! Thanks.
